Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 03-31-2007, 09:42 PM   #26
pcmcobra
pcmcobra's Avatar
Re: serpentine setups..info please
Question...
I bought the tpi setup, only no smog pump delete pulley.
Instead of buying the pulley...what belt can I use? Any one have a part # for the slightly shorter belt?
thx
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline
Old 03-31-2007, 11:57 PM   #27
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by pcmcobra View Post
Question...
thx
When I purchased my brackets, I got a belt from S&P for the setup W/O the air pump and idler pulley. I have yet to try it, but the number is GOODYEAR 4060960 6PK2440.
piecesparts is offline
Old 04-18-2007, 07:51 PM   #28
sneezys72
What needs to be done to the rest of the ac setup. I got the serpentine brackets with the new Delphi compressor and will be putting it in soon. I will also be adding the ac as my truck doesn't have it yet. I have a stock ac setup minus the compressor and brackets. Can I still use this, or do I need the condensor, dryer, etc out of the new model? Also how deep do you need to drill into the head (not mine, the one on my truck)? I just want to be sure of these answers before I start because it is my daily driver.
sneezys72 is offline
Old 04-18-2007, 08:02 PM   #29
pcmcobra
pcmcobra's Avatar
good questions sneezy,
I was going to ask about the depth/size of hole in the head....Mine is on the back burner for a few weeks at least.
pcmcobra is offline
Old 04-18-2007, 09:05 PM   #30
piecesparts
We drilled one of my heads for the brackets and went in about 7/16 of an inch.
Old 04-19-2007, 11:04 AM   #31
Zoomad75
K5Camper
Zoomad75's Avatar
Here's the best way to gauge the depth. Go to an existing hole and run a bolt in until it just bottoms out. Mark the bolt where it's flush with the head. Remove the bolt and measure from the end to the mark you made. to be safe I'd take a 1/16th of an inch off as a saftey margin, not to go too deep. Transfer that measurement to your drill bit with a piece of tape and drill to the tape.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline
Old 04-19-2007, 11:29 AM   #32
pcmcobra
pcmcobra's Avatar
zoomad,
good answer, wished I would have thought of it...
thx
John
pcmcobra is offline
Old 04-19-2007, 12:01 PM   #33
Zoomad75
K5Camper
Zoomad75's Avatar
No problem, just be carful not to drill too deep! Plus you got to keep the drill perpendicular to the head in two directions to make sure the hole is straight. I know DirtyLarry said he was pretty spooked about taking a drill to a cylinder head when he did it. take your time, use a sharp bit and plenty of cutting oil. Clean the hole out often and let the bit do the work. This isn't like drilling into a 2x4. Drilling cast iron takes time. Oh and be sure to center punch the head first before you start drilling. Otherwise your bit is going to walk all over the front of the head and you wont be able to start the hole in the right spot.
Rob Z.
Zoomad75 is offline
Old 04-19-2007, 10:29 PM   #34
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I smell a sticky or tech artical. Tons of good helpful info
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline
Old 04-20-2007, 10:05 PM   #35
Here is mine. It came off a 94 C1500 with a 4.3
I didn't bother to drill the head to mount, you really don't need it it bolts solidly without the extra hassle.
In the second picture you can see where i didn't add the second bolt on the upper/inner side. You can see the brace from the tensioner to the drivers side of the head and it and the other braces make it plenty strong for normal use. There is several folks that run them that way and no problem if you don't want to go through the hassle of drilling and tapping the head.
Palf70Step is offline
Old 04-26-2007, 11:23 PM   #36
jdmaffeo
jdmaffeo's Avatar
Question...
thx
Here is the Gates belt and part number that you are looking for. I am not running the smog pump. I hope this helps.
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline
Old 05-22-2007, 08:45 PM   #37
pcmcobra
pcmcobra's Avatar
so now that I have 95% of what I need, i can get started, just missing 2 bolts for smog pump pulley.
As for all of this other emissions crapola...I am now having second thoughts about this. I don't want to put a new carb or intake on this motor, don't want to put another dime in it really. But there is some equipment attached to some of these stock brackets I am not familiar with and just don't want to get knee deep, and have one of those "uh-oh" moments.
I'm gonna post some pics and maybe you guys can tell me what I can yank off and not worry about. no smog tests here so I don't care about the emissions stuff.
pcmcobra is offline
Old 05-22-2007, 09:34 PM   #38
pcmcobra
pcmcobra's Avatar
Here goes, what I want to know is, can I get rid of this stuff that is hindering me from converting to a serpentine setup, without having to buy any new equipment, like carb/intake...
If so, can you explain what I need to do with the lines that are connected to the devices in the pics?
The last pic is a wire, and I just don't know what it is connected to, or what it does.
thx all.
pcmcobra is offline
Old 05-22-2007, 11:17 PM   #39
piecesparts
First of all, do you have smog tests in your state? If so the smoggies will make you put the stuff back on. All of the tubes in your pictures are for air injection to your exhaust system and it is required in most states. Many trucks did not have smog stuff on it, however, my 84 and my son's 85 did and now that stuff is in the trash, but I live in Kansas and we do not have smog checks. If you are free of the rules, then YES it can be removed and the holes plugged with either plugs from an automotive outlet or homemade plugs. The wire that you want to remove is not going to give you any issue and if nothing else just move it and the connector out of the way. Take the smog pump and do the ALLY-oop to the storage ppile in the back of the garage.
Look for a basic motor plan, here. Gas and air in, and exhaust out (without the cats I imagine). The dizzy and carb may have to be changed for something that is not computer dependent for operation. I put a standard HEI into my truck and then did an upgrade to an aluminum intake to get rid of the computer carb. YOu could change over to a different carb selection without changing the intake.
I have a 383 stroker motor in my truck and my son's truck has a standard 350 without the smog, and cats affecting them. Short of giving off emission gases that are not inline with California's standards (who cares about
california), we have good running vehicles.
Old 05-23-2007, 05:55 PM   #40
pcmcobra
pcmcobra's Avatar
in the post before the pics, I did mention no smog test. In Florida, they did away with that years ago. So I am good there.
thx for the input.
pcmcobra is offline
Old 05-23-2007, 06:20 PM   #41
Jonboy
Slots go on anything!
The first pics are your AIR injection pipes into the exhaust manifolds. The rest of the pics are the one way check valves to keep from putting exhaust into the smog pump. If you are getting rid of the smog pump, you can pull that off. It will not set a check engine light. You can unplug the electrical connection to the switch on the check valves and just folt it cack into the harness to get it out of the way. The last picture is your brake pressure switch (I think). If not that, it goes to a high pressure switch for the Power steering. Either way, leave that one.
Jonboy is offline
Old 05-24-2007, 11:06 AM   #42
jdmaffeo
jdmaffeo's Avatar
Yes the last picture is the brake pressure switch....Leave that one, but the rest can go if you don't have emmisions testing.
jdmaffeo is offline
Old 06-17-2007, 11:59 PM   #43
Pyrotechnic
Pyrotechnic's Avatar
Bringing this one back from the dead. This thread has lots of great info.
With the stock R12 A/C dying in my 77, I'm getting very serious about swapping to the 96-04 serpentine setup and delphi compressor mention earlier in this thread. My main motivation for moving to this setup is hopes of: Easy valve cover access with the ability to run tall valve covers and remove them easily and of course the improved efficiency of the delphi compressor.
Does the A/C compressor or alternator interfere with the valve covers at all ? I want to be able to run tall valve covers and have easy access to them if I need to adjust the rockers.
Pyrotechnic is offline
Old 08-14-2007, 08:48 PM   #44
pcmcobra
pcmcobra's Avatar
Im still having a tough time w/ the ac. I bought some 92 firebird ac hoses, but not working/fitting right with my drier, and also a little long to condenser, kinking the hose. Local ac shops want $200 just to make lines using my existing lines.
Any ideas?
thx
pcmcobra is offline
Old 08-14-2007, 11:37 PM   #45
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The serpentine belt system leaves plenty of room to remove the valve covers. Eventually I'll change mine to chrome.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline
Old 08-15-2007, 12:13 AM   #46
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Why not buy hoses for a 91 Blazer with a 350? They had serpentines...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline
Old 08-15-2007, 11:38 AM   #47
pcmcobra
pcmcobra's Avatar
well, I did.
Went to oreilly's and that's what I asked for, but what I got would not fit. Maybe I will try a different place. Maybe they got me the wrong ones?
thx
pcmcobra is offline
Old 08-15-2007, 02:29 PM   #48
Pyrotechnic
Maybe they were thinking S10 Blazer ? Tell them 91 V10 Blazer, or even 91 R10 Suburban. The R10 Suburban was the only Surburban that year, maybe thats a little more fool proof for parts counter workers ?
Old 08-15-2007, 07:10 PM   #49
liljon285
That Guy
liljon285's Avatar
I guess im unique cuz i have not seen one truck with the one i got!
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline
Old 08-15-2007, 07:33 PM   #50
piecesparts
My local NAPA makes up hoses and I know that the cost will be up a little, but it is not around $200.00. Of course this depends on how much hose and how long you want them.
