Old 03-30-2007, 07:26 PM   #26
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Re: Stepside bed does not sit level!
color is 63 light bronze metal.
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 03-30-2007, 07:52 PM   #27
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Stepside bed does not sit level!
I'm with jeff i think you need to remove the bed stand it upright on the front end so you can visually inspect all of the cross supports 2ea the supports are the ones that the mount bolts will pass through and will have a large hole and the cross sills 2ea will just be bolted to all the wood planks by way of the bed strips.
There is also a cross support at the tailgate end and it will have two stand off brackets that you will need to look at and they could be bent or missing or the spotwelds have come loose.
Also visually inspect the truck frame rails for any defects like cracks, bent, repair splices, signs of heat from a torch.
While that wood isn't in the best shape it's not the problem i'v seen alot worse and the bed was still level.
That should keep ya busy for awhile and hopefully you will find a major discrepancie some where.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 03-30-2007, 09:12 PM   #28
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
That is a lovly color hence y my truck is staying that color. I still stick to all my older ideas nothing else that i can think of.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-30-2007, 10:52 PM   #29
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I'm installing my truck's bed floor in the next couple of weeks this is not the problem with your box. My box was off about 3/8 of an inch and I shimed it and this cured the problem. This looks to me to be a shiming problem. These frames (any mass produced frame for that matter) has shims installed at certain points (main mounting points) to correct this problem. Frames are not 100% true and shims pick up the slack. I would be surprised if the drivers side has any shims installed. I go to a local conveyor belt company and get scrap belting as this makes perfect shims or you can buy them from your favorite supplier.
Sagging coils can also aid in doing this. When I got my truck all the shims were missing!!!! Make sure that the main mounting points are in good shape!
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-30-2007, 11:30 PM   #30
bigblock73
yeller
bigblock73's Avatar
My 73 didn't & doesn't have shims...it is a fleetside however, didn't know/not sure if any 73-87's used shims.
bigblock73 is offline   Reply With Quote
Old 03-31-2007, 12:57 AM   #31
ureckme
ureckmefixit2@cox.net
In 25 years of doing frame work I have never seen shims under a bed to make it level.
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 03-31-2007, 02:40 AM   #32
EAST SIDE LOW LIFE
Rubber pads, I call them shims are a 1/4 inch thick.
* Mar K Part #120181 they show only 6 but they come in a set of 8.
esll.
Old 03-31-2007, 03:41 AM   #33
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Originally Posted by benoit454 View Post
I retract my previous statement, the cab and bed clearance looks to be equal all the way up.
Agreed with the above, could be unlevel ground.
Now that you mention it in the last pics the front of the bed sits pretty much level with the cab, and only the rear is tweaked... These frames have a lot of flex, I can twist mine by just jumping on the rear bumper and shaking it left and right, so maybe it's mainly uneven ground issue? Rc415, get under the truck and look at the driver-side rear-most bed mount, is it collapsed or bent? Any damage to the frame there?
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
