#26 |
Re: The unfindable tapping noise
definetly will buy something besides paper
69 C10 a long way from done |
#27 |
Dave's not here, man
I use a Felpro gasket that has metal on the manifold side. I have ramhorn manifolds instead of headers, but these hold up extremley well.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#28 |
Well I replaced the gaskets last night and I still got the tick. Ive checked the flywheel too, no teeth missing; balancer looks ok; still havent replaced the fuel pump although I did buy one. Now Im getting worried I guess tonight Ill do the fuel pump and check the timing chain after that I have no idea what to do besides take it to the local old school and let him check it out. Thanks guys for all your ideas.
#29 | |
![]() Join Date: Feb 2007
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#30 |
GEARHEAD
Although I hate to mention it, when a connecting rod bearing is fried or the cap is loose, it will make an inconsistant tapping. Mostly when under load. I had a cap that cracked on an engine rod and needed to nurse it home (didn't make it), that's what I found.
Best of luck, HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#31 |
![]() Join Date: Mar 2007
I had the same problem with my 427. The main bearings were shot.
#32 |
Its funny you say that because I was just coming to post that I noticed something today, it only does it when its NOT under a load. If Im going up a hill or just accelerating I usually dont even hear it. I bought this truck under the assumption that the engine only had 400 miles on it Im getting the feeling I was lied to If I tear into the engine and find that I was lied too then I WILL post his name here since he does alot of selling of these old trucks but I will make damn sure before I do. Thanks guys and hang in there, with yalls help I will get to the bottom of this.
*edit* Can I check the rod bearings just buy dropping the pan?
69 C10 a long way from done Last edited by dogfishguzzler; 04-05-2007 at 06:13 PM. Reason: forgot something |
#33 |
Oh well I was just laying under my truck with a steth and good news I heard nothing from the oil pan area HOWEVER something caught my eye and I notice that the tail pipe is spitting water so I guess I get to pull heads off!
#34 |
Not necessarily, fuel gets water in it, if you smell the exhuast, does it smell sweet or have white smoke? If not, dont pull the head unless you just want to. If you have a flat lobe you would hear a popping. You can pull the pan and look for a blueish colored cap (if the bearing is thrashed the rod cap will discolor from the heat). Good luck.
#35 |
It does have white smoke but very wispy not real thick
#36 |
The exhaust should have a little water coming out. Remember CO and H2O are by products of fuel cumbustion. So don't go yanking the heads off just yet.
#37 |
yeah Ive decided to wait until tommorow, I forgot to check the oil for milk anyway so tonight is beer and tears lol. You guys keep giving me your wisdom cause I need it.
BTW Steve I have a friend in Kalispell. last name Fumich.
69 C10 a long way from done Last edited by dogfishguzzler; 04-05-2007 at 08:55 PM. Reason: seen something |
#38 |
small world. enjoy the frosties.
#39 |
btw this water was enough to leave two wet patches on my driveway
#40 |
after idleing for a while? If you had more compression it would spit further!
#41 |
lol figures youd say that! I got a good three feet anyway
#42 |
Broke and still trying
Maybe an exhaust leak or cracked header/manifold. i have a large crack in mine...gives it character! Ticks but really helps get the exhaust cracking when I let go of the gas and it vacuums. NIIIIIICE.
