Old 04-10-2007, 02:19 AM   #26
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: What did you get done? Easter edition.
Originally Posted by strokd 84
I had the pleasure of working on my buddy's little brother's car. He's 16 and quickly learning why we don't buy Fords. First it overheated, so we replaced the thermostat and water pump. Now it doesn't over heat. But, the check engine light comes on, so we replaced both 02 sensors. The second one near the firewall was so tight that my girlfriend was the only one who could get her hand in the hole. We got them replaced, but the light is still on...
Wish us luck.
Hey now, there are plenty of good Fords out there... most of them don't have a check engine light tho What car is the one you're working on? The CEL can come on for many reasons, loss of signal from a sensor is one of them - since it's been overheated, have you guys looked into the coolant temp sensors, particularly the one that feeds the PCM? Also in many of the '80s V8-equipped vehicles the light will come on when the oil level or pressure is down, believe that feature was retained in the newer models too - both of these will throw you a code usually right about never...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 04-10-2007, 03:57 AM   #27
wklink
Junior Member
wklink's Avatar
Scrambled to the the 550 sqft of hardwood flooring in the living and dining room done in time for Easter dinner with our friends and family only to have my wife inform me Friday night that everyone has decided to change the thing for two weeks from now so a friend of my wife can make it.
Yes, there are some good Fords out there. My Fairlane and Thunderbird are pretty good cars. But you are right, neither one of them has a check engine light. The Fairlane is a 65 and my Thunderbird is a 62.
I let my 16 year old son drive my every car that I own. I don't let him drive my truck. A man has to draw a line somewhere.
wklink is offline   Reply With Quote
Old 04-10-2007, 11:13 AM   #28
boatpuller
boatpuller's Avatar
Originally Posted by jr2 View Post
Boat,
If you mount your swaybar with the standard drop mounts it will be a nerf bar for curbs?? Just do like Scoti said and I did and mount it right to the frame like this:
Finished product tucked up nice & tight!
Then you only have the lower control arms as nerf bars.
thanks for the pics jr........you,scoti,n2trux have all said the same thing about not needing those brackets,hell i'll save some bucks too.mine had a mangled one when i got it,tore it off so i never drove it with sway bar.so,i'm looking forward to a improvement.as far as lca nerfs,got the scars man.i think alot of us lowered guys do.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 04-10-2007, 03:58 PM   #29
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Getting in late on this, but this weekend I got the Burb running again. It kept dying and would die when going into gear. After digging into it this weekend I found the PCV port was completely stopped up. So far so good.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-11-2007, 01:50 AM   #30
strokd 84
strokd 84's Avatar
Thanks for the tips. The car is a 95 Ford Contour with the 24v v6. We haven't hooked it up to a diagnostic machine yet but plan to this week. Hopefully that will turn up something. I pray the something is a simple/cheap something...
1984 Silverado SWB
Second Owner
Featured in Custom Classic Trucks May 2013
http://www.customclassictrucks.com/f...let_silverado/
strokd 84 is offline   Reply With Quote
Old 04-11-2007, 01:38 PM   #31
AceX
>130dB Moderator
AceX's Avatar
Replaced plugs, wires and belts...
AceX is offline   Reply With Quote
Old 04-11-2007, 02:38 PM   #32
82c10
needin' money
also it could be the gas cap is not screwed on tight enough, take it to the local vo-tech, or take it to orielly's or autozone, or whatever is in your area
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
