#26 | |
Re: pics of fuse block wiring cover
" Never look up a dead dogs butt." ![]() |
#27 |
Parts and more parts
My 84 is chromed out and AI took all of the wiring that ran across the motor and put it down into the frame, then it comes out at the appropriate points for the accessories that it feeds to. I did keep the original brackets and the A/C unit, I wish I had not now, but my plans have gone another route for the next truck. The radiator is an aluminum one from "Be Cool" with two 11" electric fans, then polished aluminum pulleys and chrome vlave covers centered with the Endurashine intake and water pump from Edelbrock. I then polished the aluminum A/C lines and accumulator, as well as the brake booster. The master cylinder is trimmed with a Stainless steel cover that I made and the battery is covered with dark tinted lexan. The brackets for the carb, power steering and small accessories is powder coated in a silver metal flake. The inner fender walls are covered with stainless steel sheeting, as well as the cover for the firewall electric plug being polished.
#28 |
Chris
Ok guys, stop telling us how nice your stuff is.....
AND SHOW US!!!!!!! You guys got me dying to see the nice cleaned up pictures of the wiring, also got me wanting to go out on the bone stock 84 and start yanking stuff and cleaning it up!!!
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#29 |
yeller
Here are some pics of mine, I have made more progress but need to take more pics.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 04-11-2007 at 09:20 PM. |
#30 |
jeff,thats gonna be so sweet...you do nice work
#31 |
Chris
Man that's really nice I love that, it's my favorite color too!!!
#32 |
Wishin' I had more money!
Dumb question for Jeff, but is that the factory mounting location for the ICM and Coil? My truck was HEI equipped so I never had a coil or an ICM, but if that was your own idea, I have to say, that is VERY impressive!
#33 |
Professional Grade
Looks good Jeff! What are you plans for heating?
And I love the idea presented in the first post -- You can be sure I'll be doing the same on my truck ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 04-12-2007 at 01:29 AM. |
#34 |
yeller
Thanks for the compliments guys.
![]() The ignition box and coil are definately not stock. I chose to mount them on the inside of the firewall under the dash...to clean things up. I ran a terminal thru the firewall just behind the distributor, so I could get the power to it from inside the cab. I am not a fan of bolting aftermarket goodies like this in plain sight, too much distraction IMO. Since my truck will never see a snowflake in its life (ie not driven in the winter), I removed the heater box and A/C. I never cared for the looks of the factory setup, and cannot afford an aftermarket heater/AC setup...so I yanked them. I will however, be installing seat heaters in my factory buckets...for those cooler spring and fall days/evenings.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#35 |
Chris
I'm in the same boat on my monte carlo, the heater is long gone, and the big old box was ugly anyways. They made a non a/c setup but thoose boxes are like gold, if you find one they want $200 or more for it.
Mine never sees snow either but when it's cool or rainy and you get caught with no heater it sucks. I plan to fab my own blower motor housing and heater core housing from aluminum to mount them then run the wiring, and relay's what not to control it. I don't plan on reusing the factory switch and controls because I have my uages mounted where it was, so I'm thinking simply switch for high only. Then use relays or whatever to avoid overload or burnouts on the switch or wiring.
#36 | |
http://cgi.ebay.com/ebaymotors/68-69...QQcmdZViewItem
#37 |
My original heater box ins't very big?
![]() It does still have the heater core in the original location so the hoses and wiring hang out but it is pretty clean. I'll get another shot of the hoses mounted up and the wires cleaned up.
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() Last edited by jr2; 04-12-2007 at 01:26 PM. |
#38 |
Great looking job Jeff! Super Sano!
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() |
#39 |
Chris
Yea the truck heater bozes are small I like them.
The ac ones are big, and the one I was talking about is in my monte carlo, that things almost as big as a dog house on a van. Yes I have considered thoose heater boxes, ones for monte carlo are like $175 I think. That's almost as much as an original, but easier to find. I figure I'll make my own and save cash, if it turns out good then it'll be a head turner, and always get questions on how it was made or by who. I love when people do that, if not then I'll buy one of thoose and use it. Also another option is the mojave heaters from summit, they are about $175 and it's a complete heater unit to mount under the dash, uses the engine coolant for heat, just like the vintage air ones, but it's heat only, even comes with brackets to mount it. Then you can fit it to your duct work or buy one of their ductwork kits.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 Last edited by benoit454; 04-12-2007 at 03:38 PM. |
#40 | ||
Until Seventy Times Seven
I bet it still looks good. ![]() Quote:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#41 | |
That's looking real good. A-1 ![]() Keep it up. ![]()
#42 | |
#43 |
#44 |
Give me some time--I am headed to the big swap meet (at the Woodlands dog track) in KC this weekend and I will get you what you need when I get back.
#45 |
BTT boys...
OK I got the cover done. It ain't no work of art but it get's the job done that I created it for. It attaches to the 2 E-brake bracket mounting studs in the firewall. I didn't have to drill any holes that way. Used some aluminum, box bent it and riveted the top 2 corners then polished. Before: ![]() After: ![]() ![]()
#46 |
The Crazy Machanic
nice you can now start selling them on ebay.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
#47 |
I don't have enough time in the day to sell em. Sure it would make money (maybe) but my time costs me a pretty penny when I can get it. I made some other hammer formed stuff a while back for my dads motorcycle and people said I should sell them too. Not enough time
#48 |
The Crazy Machanic
yea i hear yea never got enough time. Or money for parts:
#49 |
If you want to get better close up pics., try setting your digital camera to the macro setting!!!
#50 |
Chris
Nice work, I see you got heater hoses now, love thoose also very nice.
Great looking piece and great idea using exsisting studs to mount it. I think I may fab one up the same way but painted aluminum. I got some old flashing laying around or house soffet(sp?)
