Old 04-23-2007, 04:50 PM   #26
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Re: Well I learned something today.....
Hey Mods...this started off as just a venting but since I'm gettin advice and showing pics feel free to move it to the proper forum!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 04-23-2007, 05:23 PM   #27
69face
69face's Avatar
you gotta read the inside panel for the settings better if it has a setting chart. that first pic looks pretty gasless. are you tacking and then hammering and dollying. because that prevents warpage(i learns that one the hard way). looks good enough for a skim coat of bondo imho. just find scrap and have fun with that first.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 04-24-2007, 03:32 PM   #28
Draggn66
Draggn66's Avatar
Hmmm what should the gas regulator be set at? I thought I read it should be set at 15-20. I've got it set at 20 so maybe I need to increase it a bit?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 04-24-2007, 06:04 PM   #29
hootlube
Wellllll....
It looks OK for first efforts...
I'm like the others, I'll start with tacks, go all the way 'round, then start filling. I found that you can't really run much of a bead on sheet without warping. So, I try to keep my beads (after all the tacking) about 1/4" or so. And, the more you grind, the thinner (and harder to weld) the metal gets. Practice makes perfect? Yeah, right. Whoever said that never tried to weld sheet on a rustbucket.
hootlube is offline   Reply With Quote
Old 04-24-2007, 07:57 PM   #30
Smitty
Smitty's Avatar
I just recieved the May copy of Custom Classic Trucks and they have a pretty extensive Tech article about Mig welding for dummies like me! The source is the Miller welding Co. So don't give up yet help is on the way.
Always remember set up and prep are the two most important parts of any project.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 04-24-2007, 09:25 PM   #31
harleyx2
change your gas to 40 and use 023. wire
harleyx2 is offline   Reply With Quote
