#26 |
Weekend Warrior
Re: It shrank!!
I thought about it - looks scary, but I guess it works
![]() $50 @ NorthernTool http://www.northerntool.com/webapp/w...atchallpartial
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#27 |
Re: It shrank!!
Hello....in reference to making a LWB to SWB bed.... what were the measurements from the front? I got the ones in back 81.5/89.5 Can you help out?
#28 |
Re: It shrank!!
Do you have info from the front? I just need that so I can measure from the front
#29 |
Back in the sticks
Re: It shrank!!
Mark, that bed looks great! When can you do my 71? Ha, J/K, its gonna get the cab extension like on your other project.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#30 |
Re: It shrank!!
Hey Mark, can you give us the measurements and starting points for them. I wanna start on mine this weekend. Thanks.
#31 |
Re: It shrank!!
I was looking at this on my truck last night. For the front, it really doesn't matter too much exactly where you start. You just need to remove 12" and make sure you remove one of the crossmembers. (mine has a non-existant wood floor, so I can see the crossmembers)
From memory, starting about 3" behind the front stake pocket would work. Double check though. |
#32 | |
![]() Join Date: Apr 2005
Re: It shrank!!
http://www.67-72chevytrucks.com/vboa...d.php?t=321099
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#33 |
Re: It shrank!!
this is probably a stupid question but is there anything you have to do differently when cutting a bed with a wood floor as opposed to the steel floors. All the conversions i have seen have been done with the metal floor.
1970 c/10 swb (show truck) 1972 custom/10 deluxe 4x4 (restoration pending) 2011 silverado ecsb z71 (daily driver) |
#34 | |
Re: It shrank!!
I just ran one 1x1 across the top of the main portion of the bed and the tailgate portion. Seemed to work out good. When I removed the rear 8" section, it all came out as one piece since that crossmember wasn't bolted down any more. Good luck! |
#35 |
Re: It shrank!!
thank you!
#36 |
Re: It shrank!!
This is some good info. I am going to cut down my 72 LWB starting in June. Wish me luck.
#37 |
BlahBlahBlah
Re: It shrank!!
Good luck...Make sure you post lots of pictures of the process. Unless you chop off a finger, I dont want to see that
#38 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: It shrank!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
