#26 |
Re: What did you get done? 05/06/07
Did the Backstroke in Maggie Valley. Actually had a great time there. I sat across from LUV as he devoured the ribs. I have pics of the frenzie and will get them posted soon.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
#27 |
pulled a 350 from the yard cleaned it up resealed and painted it i,installed a new timing set and installed it in my 69 driver not quite finished but the hard part is done. just got the exuast , carb and alt left for tomarrow
common sense isn't so common anymore |
#28 |
#29 |
![]() Join Date: Oct 2005
Continued to install new wiring. Using an EZ wiring kit....... and talk about time consuming!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#30 |
someday it will be done!
Drove to Reddeer for a swap meet on Sat.It was a great meet!Bought a few new tins to add to the collection,a couple of johnny lightning trucks,ordered up my steering column and steering wheel,and talked about a set of strong arms for the moneypit.
Today I spent the day shining up the GP (had it professionally detailed a few days ago but it turns out that I'm a bit pickier than they are). ![]() I enjoyed my weekend muchly!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#31 |
Questionable
man, i wanted to get the wiring and chydraulics for the clutch installed on the truck, but somehow i got suckered into doing landscaping in the yard - cut about 10 square yards of sod out and planted a bunch of gardenias, hydrangeas, rosemary and assorted other stuff.
![]() close on my house tomorrow, travel for work next weekend ... bleh. On a side note, Saturday I picked up a cowl with no antenna provision from board member 'uncle' - always a pleasure to deal with him (thanks, Tim), probably one of the nicest guys on the forum to do business with. I also got a pretty nice passenger inner fender. Will proceed to shave the battery provision out, DA the thing, paint it up and reinstall it in the near future (after the other stuff is done)/
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#32 |
Commander Taco Bello
completed the wiring for my bag setup and fired up the compressor and valves for the first time. Also got all of the line run for the compressor, tank and valves. All i have left is to finish drilling the holes for the rear bag mounts/fill (what a pain in the ass) and run the line for the bags.
Once that's done, work begins on the front. pics are in my build thread (will be shortly) linked in my sig. |
#33 |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Went to the car show in Silvana on Sat. Showed the flatbed and meet droppedgmc with his swb 68. Then today loaded 2000 lbs of garbage and went to the dump.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
#34 |
![]() Join Date: Jul 2006
No work on the truck, but I did pick up my new Eaton Compressor on Saturday and started the installation.
Arrival... It's new home...
Cheers, Tony A day without sunshine is like, you know, night. 1970 Chevy CST10 (Green) 2005 Silverado Z71 2000 Pontiac Bonneville |
#35 |
Next project: 1970 K10
On mine, I got most of the cab seam sealed, finished welding the last few remaining holes on the firewall, layed down the skim coat and sanded, touched up a few spots with Metal Glaze, and got the template for the new dash made. Also got the outside of the bed sanded completely and ready for primer.
On Dad's, got the Performer intake/carb installed. Had to rejet a couple steps lower on both ends, but boy did that swap make a huge difference! Also got the transmission linkage at the trans swapped out (it was WAAAY worn out), and got the TH400 kickdown hooked back up and working.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#36 |
Got a new 4 -core desert radiator in, just in time for the another Arizona "global warming" episode!
#37 |
Bought some rally wheels, caps, and rings. They are a little rough but a little cleaning made them look pretty good. Now, I just need tires.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
#38 |
Pulled the motor out of the K20, then pulled the donor motor out of the Monte Carlo. Cleaned up the new motor, swapped accessories & brackets, then sold the Monte Carlo to keep the wife and neighbors appeased. Hopefully the new motor goes in today.
#39 |
Need a bigger hammer..
It looked like my driveway didn't have enough oil on it, so I let the 68 drop a few more coats on it...
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
#40 |
huh?
![]() Join Date: May 2000
Started working on the outside heater box on the 68, getting ready to get it put on (after 5 years), and broke the air door. So I cussed a little and gave up for the day. I have a new heater box on the way (thanks Wornbrakes), so I'll do that next weekend...
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#41 |
![]() Join Date: Jan 2001
had a bbq with the locals!!
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
