05-22-2007, 11:03 PM | #26 |
A guy with a truck
Re: Guess its a start
Just use a piece of 6" pipe. The bolt-in style notches cause too many fitment problems. They want to occupy the same space as the upper spring mounts...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-23-2007, 11:29 AM | #27 |
AttentionDeficitDisorder
any chance you could take some pics/measurements of how you mounted/lined up the front 2wd suspension crossmember? what you used to center on etc? use any factory holes or drilled all new ones?
05-23-2007, 12:14 PM | #28 |
Sweet!
05-23-2007, 01:46 PM | #29 |
From a 4wd to a 2wd But it's all good, as long as you enjoy all that work!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
05-23-2007, 02:46 PM | #30 |
It's ok to stare...
Nice progress so far.
05-23-2007, 06:28 PM | #31 |
Cereal Killer
When I get the front suspension im going to run mounted I will try to get some concrete measurements for a 4x to 2x swap....its info that others could find helpful. Right now I have a 72 front crossmember in but plan on replacing it with one from a 73-87 truck with 1 1/4 brakes....much cheaper to rebuild plus my buddy OJOE has access to the parts.
If I dont do it....somebody else will. |
05-23-2007, 08:19 PM | #32 |
69fatmotor
if your gonna be working on it tomorrow afternoon give me a call ?
05-23-2007, 09:24 PM | #33 |
Cereal Killer
Will do Mike.
05-23-2007, 10:32 PM | #34 |
The LuvShack Garage
Me either, giving me evil thoughts about converting "GQ" to a 2wd
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-24-2007, 08:40 AM | #35 |
C10 Club Tennessee
nice start
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
05-24-2007, 11:53 AM | #36 | |
2wd FTW!!!!
05-25-2007, 06:20 PM | #37 |
Cereal Killer
Got the floor roughed in today along with the front cab mounts...also got the firewall stuck back in position but was too worn out to put the doors back on to see if they fit yet...going to get the 87 front suspension stuff off truck tomorrow and get it steam cleaned so I can start on that soon. No pics today..The one piece floor without braces looks like its going to fit pretty well.
05-25-2007, 06:36 PM | #38 |
Good deal, I was getting ready to try that on my Blazer.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
05-25-2007, 08:03 PM | #39 |
Cereal Killer
Im not sure how the floor with braces would work out....would be easier than cutting all the spot welds and also have fresh clean braces but I would imagine you would have to modify the back ends of the lateral braces.
05-25-2007, 08:19 PM | #40 |
I just figured that one would be a waste of money, since the back brace would be completely unused.
05-25-2007, 08:26 PM | #41 |
The LuvShack Garage
If I could sell all my 4wd stuff to finance the swap I would, I'd
really just prefer another 2wd frame. (Missed one last week )
05-25-2007, 09:29 PM | #42 |
To me it seems as this solid floorboard is a no-brainer. You would have to make a 90 degree bend at the cowl and also a 90 degree bend at the step up. Adds up to a lot less exposed welds and alot less cutting and fitting. Then just cut out the low hump and bolt in the high hump. I am probably over simplifying it, but if that part was available a year ago I would be done my project, or maybe not...
The only area that concerns me is the lower 'B' post area. There is a tricky little complex bend in the floorboard to step up area, but if you run your rocker backing plates long you should be able circumvent this problem area. Post up your progress as I am very curious of your out come...JMHO J. If your existing lateral braces are in good shape, I say keep them, and use these to build off of.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-25-2007 at 09:32 PM. |
05-25-2007, 09:43 PM | #43 |
Cereal Killer
The cowl is the same trucks/blazers. Im leaving a small strip in the rear to keep from having to deal with putting that flange in.
05-26-2007, 05:46 AM | #44 |
That sounds like it would be even a better idea...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-29-2007, 04:43 PM | #45 |
Cereal Killer
Got the front 2wd crossmember all bolted in, the only thing I havent gotten done is the idler arm drilled....I have measured and measured but still dont have placement right. If anyone has a suggestion for help I would love to hear it.
06-01-2007, 10:20 PM | #46 |
wondering if anyones just welded their 2wd crossmember in as opposed to dealing with bolts?
