Old 05-21-2007, 06:58 AM   #26
70GMCer
70GMCer's Avatar
Re: so what have you guys accomplished this weekend
Started the process of putting together my 383......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-21-2007, 07:20 AM   #27
smoky02
Location: Sunny, Florida, some might call it South Alabama
man that's pretty...installed the 27 gallon gas tank, and motor and tranny. Also ran the fuel line, just gotta pick up an inline fuel filter.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 05-21-2007, 09:24 AM   #28
fade94
fade94's Avatar
Installed the fuel cell and removed the in cab tank. Installed the new solid trans cooler lines. Took the truck to the local 1/8 and let my 17 yo son abuse it. Did a very nice job too.
Only carnage is a burnt fuse for the fans, heater core now leaks and a blown pass side header gasket.
Replaced the fuse, will disconnect the heater core and I have the new header gasket on the bench. Too bad it won't install itself.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 05-21-2007, 09:56 AM   #29
70c10
67-72 Addict!
70c10's Avatar
WOW . That looks sweet Steve!.
I repaired one fence and started building another one I'm staining the deck and opening the pool this coming weekend but the following weekend I can help you put the motor back in if you have it ready by then!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-21-2007, 11:41 AM   #30
truckdude239
truckdude239's Avatar
pulled the motor out of my 87 f-150
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-21-2007, 05:42 PM   #31
truckdude239
heres a ttt
David fuller
2000 Tahoe 5.3l 378
Old 05-21-2007, 10:56 PM   #32
MXmaniac
MXmaniac's Avatar
I sprayed my truck in it's original green.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
