Old 05-28-2007, 07:16 PM   #26
lukecp
Formerly yellow72custom
lukecp's Avatar
Re: mileage motors
3.08 was standard on most trucks in the 80's, and I've heard of even 2.73's....with a 700R4. One of my friends had an '86 K10 with a 305/700R4/3.08 combo. With 32" tires it practically idled down the freeway, but got maybe 10-11 mpg going 75, and had no power, with its worn out, improperly tuned 305.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 05-28-2007, 08:12 PM   #27
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: mileage motors
I would recommend one of the smaller Comp Xtreme 4X4 cams. They produce great low end torque, and helps the push the truck down road better, The problem with a small cube engine sometimes that that you have to give it lot of throttle to make them feel like thay have any power negating the fuel mileage advantage of having a smaller engine. If you can do it, get the CR up to 9 - 9.5:1 and go with a cam designed for low end power. As Pynotechnic said, I would get a freshly rebuilt Q-jet if you can't go with EFI. 18 - 20 MPG on the highway should be no problem with a high geared rearend.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-29-2007, 06:43 PM   #28
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: mileage motors
My 305 has 189,000 miles on it.
It came from a '77 Monte Carlo.
It was repeatedly overheated on a trip from OK to Calif. & back.
Has only a 2bbl carb
Sat for a year before being put in the truck.
Best milage (after tuning it up a few weeks ago) was 18.6 mpg for 1 tank.
Before it was 15.mpg. In the Monte, best was on a trip from OK to NM was 21mpg.
I am running 3.73 rear gears, stay about 60 on the highway.
Future plans: 4bbl Q-Jet or Edelbrock, 3.08 gears.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
