#26 |
![]() Join Date: Apr 2007
Re: Interior custom ac pics
WOW ! Slick truck, nice job
02 Blazer 66 lwb step 66 lwb feet :flagw Working to live not living to work RIP RS |
#27 |
nice truck coolair very clean
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() Last edited by fercho71; 08-07-2007 at 12:41 AM. |
#28 |
Registered thread killer
SWEEEEEEEEEEEEEEEEEEEEEEEEEET!!!!!!!!!!!!!!!!
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift |
#29 |
Thanks for the comments guy's......The AC system is from Vintage Air (I'm the tech support dept.) as I work for them I did get a pretty good deal and used as many parts that we offer such as the thermostat riser, hose clamps, Aeorquip EZ clip hoses, Front Runner drive system, Spal dual fans and the Gen II Compac evaporator. A typical complete AC system will start off around $900.00 and can go as high as around $3000.00 depending on the components you choose.
As far as the steering wheel, it was a close-out @ JC Whitney and the Sony radio/CD/XM receiver from Crutchfield. If anyone has any AC questions or questions about the truck, let me know....best way to contact me is to email me - tech@vintageair.com. Thanks again, Mark |
#30 |
ur truck is sweet man good job on interior
#31 |
Junior Member
Sweeeeeeeeeeet looking truck! Congrats!
Great stance too. Is that about a 4/6 drop? and is it all mechanical - i..e. no bags or cutting frame??
64 Short Step 327 3spd |
#32 |
Very Cool..."Coolair" I would like to know a little more about the AC system as well. Do you have a website I can check it out at?? What is the size of that immaculate green motor?!
Sorry u already answered that!! Will that system work with factory Air? My tuck has air in dash from factory but lacks compressor, lines, evaporator, and coil...
"Hope you brought your wood screws...Ima blow ur doors off!!" Last edited by tjchevy1965; 08-07-2007 at 11:11 PM. |
#33 |
Me too, I did not know you could get a system for $900
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#34 |
We do have a web site - www.vintageair.com - go to the online catalog to view all of the products available. We do not recommend mixing OEM components with new - it may work but who knows how well. Installing all new components that are designed to work together with the newer 134a refrigerant is a better way to go - you also get a 3 year warranty. If you have the FAC vents in the dash, you can connect our duct hoses to it to make it look original.
As far as price goes - for a complete cool only system such as our Slimline or Mark IV under the dash system along with the compressor, brackets, hose kit, safety switch, and condenser - it will cost just under $900.00. If you want the Sure fit kit or a universal Gen II system with related components, it would be in the $1100.00 price range. The more options you add, the more $$ it will cost. Thanks Mark |
#35 |
Your truck looks great. I'm planning on getting a vintage air kit as soon as mine starts going back together. I live in Vegas so I'm definitely going to need it.
Where did you get your serpentine accessory kit and electric fan/radiator set up? I've been looking around for a while but haven't found what I want yet. Thanks
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#36 |
CoolAir. Great Job. Just ordered my AC today, your Cockpit Pics will help a
lot. But I'm really interested in your dual fan setup and shroud. What is it? Perfect setup. Got to have one like it. Thanks in Advance
1966 Chev C10 Custom LB Built 327ci, 700R4 Stage II, Mezier Elec Water Pump, Vintage Air, CPP Disks w/ABS, 22" Billets w/ Goodyear Eagle Low Pro's, Rear Pan, Hidden Hitch, Bagged |
#37 |
Looks real nice! Like a modern AC install.
'65 Chevy shortbed stepside. Last edited by Tomsriv; 06-08-2009 at 11:54 PM. |
#38 |
One day...
Very nice setups!
#39 |
Resistance is Futile
This thread is 2 years old.......dug up from ancient history.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#40 | |
One day...
#41 |
coolair, what type of bracket are you using on the front of your motor for the accessories?
#42 |
Vintage Air Front Runner - available for SBC, BBC & LS Chevy engines
#43 |
very nice
#44 |
Member of the longbed union.
What did a set up like your run? and where you at in Tx?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#45 |
A Front Runner is around $2000.00 which includes the compressor, alternator, water-pump, pulleys, PS pump, belt and spring tensioner. The AC system will start off about $1000.00 and could go up from there depending on the options you choose.
I'm in NE San Antonio. Mark |
#46 |
mark, very sweet setup!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
#47 |
chevy only
![]() Join Date: Sep 2006
that is a really bad A$$ truck
CHEVY ONLY... Nothin Else ! |
#48 |
Zombie Killer
Very nice.....
1964 C10 Long Step |
#49 |
Zombie Killer
Mark, do you have anymore shots of the install, I'd like to see where your a/c and heater lines exit the firewall.
Thanks Mike
#50 |
I'll try and take some pics this week..........Mark
