05-31-2007, 05:40 AM | #27 |
71 rustless in texas
Re: The next LFD How-To!
Hey Kevin, you used a dirty word..."Spare" time....do you actually have any of that? Or are you buying "Time offsets" like the "Carbon offsets" that's all the rage now.
By the way, how's that radiator repair you did for Low Buck holding up?
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
05-31-2007, 07:34 AM | #28 | |
I forgot about that repair, so I guess it is holding fine. I have checked for PSI in the system and it holds just fine. And yes I buy the off sets from my parent company and I get a good rate at the same time. Kevin LFD Inc. |
05-31-2007, 09:53 PM | #29 |
A guy with a truck
<-- Salivating on keyboard. Watching this one...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-31-2007, 10:42 PM | #30 |
Damb I have over 60 pics of this mod
Here are a few more showing my first lead work. I fit the hood today and it is close but I will have a little bit more melting and spooning to get the passinger side front gap just right. What do you think? Kevin LFD Inc. |
05-31-2007, 10:44 PM | #31 |
And a front shot with my new Tag!
Kevin LFD Inc. |
05-31-2007, 10:59 PM | #32 |
now everybody is gonna do this
and to think i thought i would be able to have mine complete before the trend officially kicked off.... Good work BTW
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
06-02-2007, 09:12 AM | #33 |
Well I spent some time yesterday getting it all finished up ( fit to this truck) and primmed. Turns out now that I have gone back thru my notes I have about 30 hrs into this hood. If I had done all mig welding and bondo not Tig and lead than it would be more around 15-20 hrs. I think the front gap turned out real well and all it needs now is a few block sandings and paint once the rest of the truck gets done But for now the hood part is done and I have all the build pics swaped over to this computer so I will try and work on the How-To tonight because the wife will be at her parents so I will have some free time
Kevin LFD Inc. |
06-02-2007, 11:07 AM | #34 |
Looks killer Kevin.
I don't know if it's just me...... but in the pics, that primer w/guide coat is kind of camouflaging the 'impact' the mod has on smoothing the look of the later front end.
06-02-2007, 11:37 AM | #35 |
The 67-68 hood will bolt right on but there is @ a 1" gap at the end? Your hood looks good but I dont see any pics of the gap so Im a little confused...
06-02-2007, 12:04 PM | #36 |
The gap was 'eliminated' to work w/the later style full grill-shell. He used the lip from the 69 & later hood & combined it w/a 67/8 hood.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-02-2007 at 12:07 PM. |
06-02-2007, 12:15 PM | #37 |
Now I get it. Thanks SCOTI...
06-02-2007, 01:54 PM | #38 | |
Kevin LFD Inc. |
06-02-2007, 02:05 PM | #39 |
I have a 69 GMC hood and front grill. Is the gap the reason it looks as if there was a trim piece there? I know on my 1970 Chevy there was no trim piece.
06-02-2007, 11:16 PM | #40 |
This is what i have been planning for the Blazer, but I have just about decided to make it look a '68 Blazer SS.
Mike
Mike Redpath |
06-03-2007, 02:36 AM | #41 |
Very very well done. Outstanding work as usual.
06-03-2007, 03:17 AM | #42 |
The Original HotRod KnifeMaker
Sweet, Kevin, as always.
The shops around here won't use lead any more, they say the rust problms from the lead won't hold up? I bet you figured out a way.... Thanks again for sharing your terrific work and ideas!
Dave 69 GMC SWB 2WD 454 Turbo 400 |
06-04-2007, 10:36 AM | #43 | |
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 06-04-2007 at 10:36 AM. |
06-04-2007, 04:49 PM | #44 |
So the 67 hood bolts right on but there is a gap? Do you have pictures of the hood unmodified on the newer nose?
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
06-04-2007, 05:08 PM | #45 | |
Actually, no. It won't even close. The 67-68 hoods hang lower than 69-72, their leading edge is actually part of the grill (kinda) while the 69-72 hoods tuck behind the grill. I think that makes sense? Great work Kevin. That's how they should have come from the factory!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-04-2007, 05:38 PM | #46 |
The LuvShack Garage
I saw one of these on a 69/70 at MV, looks wicked, glad you are doing this
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-04-2007, 05:45 PM | #47 |
So you took a 67 hood skin off and put it on the inner frame work of a 70 hood and then used rod to fill the gap between the hood and the grill? I love the look of the 67 hood thats for sure...
06-05-2007, 09:46 PM | #48 |
A guy with a truck
The anticipation is KILLING me!
06-05-2007, 11:25 PM | #49 | |
I know, sorry it is turning out to be a crazy week around here. Kevin LFD Inc. |
06-06-2007, 01:27 AM | #50 |
I see now, i looked at you low buck build and seen where you cut the 67 hood.. Makes sence now ... Looks great though!!!
