07-05-2007, 10:58 PM | #26 |
Re: Just want to drive it again
go see if you can save that blazer
just use a covered aircleaner in the rain youll be alright
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
07-06-2007, 10:22 AM | #27 |
I'M TRUCK CRAZY!
07-14-2007, 08:52 PM | #28 |
I'M TRUCK CRAZY!
I am going to try J B Weld the Radiator tomorrow. Hopefully
07-18-2007, 02:44 PM | #29 |
I'M TRUCK CRAZY!
07-18-2007, 02:48 PM | #30 |
I'M TRUCK CRAZY!
I put JB Weld on the radiator Sunday. No pics..... sorry. It had 2 pinhole leaks, one on each side. Next Sunday I will put it back in the truck and see if it works...... fingers crossed.
07-18-2007, 03:11 PM | #31 |
JB Weld will work, just besure it is totally dry on the inside and out so air can get to it. I did that with a gas tank once and it kept leaking until I finally bit the bullet and pulled the tank, drained it and did ti again. Solid as rock after that!
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
07-18-2007, 03:23 PM | #32 |
I'M TRUCK CRAZY!
Thanks 2bits. Hopefully letting it set up for a week will do it. We'll see
07-18-2007, 04:26 PM | #33 |
I'm a poor spectator
You gotta stop and at least ask about the blazer, it looks alright from the pics. Just stop and ask for crying out loud, i'd drive up there for that!!!!!
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
07-18-2007, 05:11 PM | #34 |
I'M TRUCK CRAZY!
My friend went and asked. It is the ladys kids truck and he wasn't home. I hate asking when I don't have any money.....
07-19-2007, 08:30 AM | #35 |
Offer them $500 and I'll come pick it up...
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
07-19-2007, 12:49 PM | #36 |
Junior Member
if you pass on the blazer let me know i am looking
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
07-19-2007, 02:05 PM | #37 | |
PorterBuilt Man Crush
Easisest way I have fouind is to use an air grinder and cut a star patern in the top of the rivet, then the air chisel will knock the top right out, then use the air chisel punch to knock it out. I had mine out in less than a minute. J72 |
07-19-2007, 02:33 PM | #38 |
I'M TRUCK CRAZY!
Thanks J72. I'll have to try that when I put a new core support in.
07-24-2007, 10:00 PM | #39 |
I'M TRUCK CRAZY!
It's been one year and four months........ I DROVE IT! Sunday I put the radiator back in and the JB Weld worked!!
This is before I took it down the road. I got to clean the engine compartment up still. Check out the custom door panels HAHA Last edited by LOW DOUGH; 07-24-2007 at 10:04 PM. |
07-24-2007, 10:14 PM | #40 |
I'M TRUCK CRAZY!
More
All the 71 front end parts and stuff Still need to put the grill on and tighten up finders, bolt on cowl, and other stuff. The grill was not bolted on in all those pics. Took it back off the truck and went down the road. It sure doesn’t ride like an 06 Last edited by LOW DOUGH; 07-24-2007 at 10:16 PM. |
07-25-2007, 07:47 AM | #41 |
Glad to hear you got it goin!!
07-25-2007, 11:28 AM | #42 |
Post Whore
Congrats on your maiden voyage. Now drive over and get that Blazer
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-30-2007, 01:05 PM | #43 |
I'M TRUCK CRAZY!
Still not ready to drive it home. Didn't get to work on it this Sunday and probably not next Sunday either. D'oh!
07-30-2007, 11:34 PM | #44 |
Glad the radiator held! That's $150 you won't have to spend! Baby steps!
08-08-2007, 04:09 PM | #45 |
I'M TRUCK CRAZY!
Thanks yall.... Sunday I plan on driving it home..... Hopefully the radiator holds in 100 deg. heat for 40 min. Someone will be fallowing me
08-13-2007, 12:19 PM | #46 |
I'M TRUCK CRAZY!
I drove it home. It was running hot at 60mph so we slowed down to 50 55. We pulled over when it was getting hot and poped the hood. Guess what. IT STILL LEAKS OIL. That is why i took it out in the first place. This is the 4th time I have had it out trying to fix the oil leak. I just don't know what it is
08-15-2007, 11:03 AM | #47 |
I'M TRUCK CRAZY!
Ok, I think it has to be the oil pan. The pan that is on it now came from a 350 that was in the truck when I bought it. That 35o blew up. I put a 305 I had in it with the pan from the 305. The old 350 pan stayed it the back of the truck with all my other junk. I drove it every day. When I put this 350 in about 3 or 4 years ago, I used the pan that had been in the back of the truck forever. I bet this pan is bent. When I get into my new house I will pull it again and put a brand new pan on. That should do it. I hope. Any ideas?
04-15-2009, 12:23 PM | #48 |
I'M TRUCK CRAZY!
digging it up from the grave. It is now in my driveway. Been there for a while. I will post some progress pics.
Oh, question..... I can't edit any of my previous posts on this thread. Is it because my name is changed and I started this thread with the old name? I was Reaper71. I can probably edit this post though. Lets see. Edit: YES I CAN Last edited by LOW DOUGH; 04-15-2009 at 12:24 PM. |
04-15-2009, 12:27 PM | #49 |
I'M TRUCK CRAZY!
Oh, that oil leak was... The bolt in the front of the block was not there. I didn't think one needed to be there cause nothing bolts up there. So, I was wrong. That hole goes into the crank case. A short one goes there and you would put a long one in while changing the fuel pump. I have an electric pump. So, a 40 something cent bolt fixed the oil leak. No more buying cases of oil.
04-28-2009, 01:37 PM | #50 |
I'M TRUCK CRAZY!
lets see..........
I put some headers on it a month or two ago. Ran into a small problem. The colectors were jambed up against the 6 cyl crossmember that was still in the truck. Fixed that litle problem. Chisled all the rivets out and got the member out. Here are some pics. Enjoy.... Here is that crossmember that was in the way and didn't need to be there. |
