Old 06-06-2007, 07:10 AM   #26
1bad chevy
1bad chevy's Avatar
Re: does this look right?
i agree you should have no problems if switched out automatics to standards and vise a versa and NEVER SHIMMED A THING in my travels if seen this a thousand times and never seen a shimmed trans in my time here's mine yes it tilts just like yours 350 sb turbo 400 trans will get a better pic for ya
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear
1bad chevy is offline   Reply With Quote
Old 06-06-2007, 08:11 AM   #27
68laydout
Junior Member
68laydout's Avatar
Mine has the same tilt and has since I bought it. I do have a 1/2 spacer on my tranny mount though. I'm running 6cyl mounts with a 350.
68laydout is offline   Reply With Quote
Old 06-06-2007, 11:00 AM   #28
crazy longhorn
Fabricate till you "puke"
Originally Posted by tranz am View Post
Hmm. I was told that the auto crossmember would work perfectly. I cant use the original bell housing because the the diameter of the front cover is too small to align it right. All the other guys seem to have the same tilt thou....... Now Im confused.
The auto crossmember does work just fine on the stick shift app(Ive done it more than once!). If you want to go back to the cast iron bell, go 67 or older & it will have the right size hole for the car trans . If it were mine, I beleive i would cut out the orig bell crossmember & shim the trans as needed, to correct any driveline issues(seeing that it is already assembled). Your truck BTW apears to be on the correct V8 stands, whereas Olchev67's is setup on the I6 stands. best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-06-2007, 11:47 AM   #29
airdale94
airdale94's Avatar
As far as I know it's the heavy duty SM465 that needs the large 5 1/4" opening on the bell housing (not actuall the year of the truck), they used the SM465 up until the 80's, and I was under the impression that they all had 5 1/4" bearing retainers, the rest are 4 11/16". If you have a sbc and a car 4-speed and th350 crossmember and sbc engine mounts you should be good. Just find out for sure if you need the 1/2" shim.
airdale94 is offline   Reply With Quote
Old 06-06-2007, 12:29 PM   #30
tranz am
tranz am's Avatar
Wow lots of different views and opinions on this one. So far Im told that my motor brackets are 6 cyl and they are V8. Im also told that the motor should be tilted like mine and it shouldn't be? Im told that I want the driveline to angle up slightly and Im told I dont? Also keep in mind that this truck will be going very low in the next too weeks. I need lots of advise on this one guys? I need to get the exhaust pipes rebent around the new crossmember ASAP but I dont want to do it untill its right.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 06-06-2007, 12:30 PM   #31
tranz am
tranz am's Avatar
Yes Please send me a pic!
My build thread
1969 GMC SWB
Old 06-06-2007, 01:52 PM   #32
71tahoe
71tahoe's Avatar
I just answered in another of your posts about the motor towers. The picture that shows the headers and the motor towers shows they are for a V8. The rubber mounts will work for either a V8 or 250 I6. Don't know about the 292. Driveshaft angle?? I'm no expert so someone else needs to correct me if I'm wrong. I researched this a few years ago when I was having problems with a lowered Datsun 620 and what I remember about reducing vibration is that you should have the rear end tilted on the same angle as the centerline of the crank/output shaft.
71tahoe is offline   Reply With Quote
Old 06-06-2007, 02:36 PM   #33
Slammed70
Slammed70's Avatar
That angle is a little steep.....just need enough angle to make the carb mounting pad level.
And yes....I know that the level is levling the wrong angle where talking about here, these are the only pics I have relating to what were talking about though.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 06-07-2007, 12:14 AM   #34
tranz am
tranz am's Avatar
I think I will shim the Transmission. and figure out the drive line latter. Thanks for clearing that up.
My build thread
1969 GMC SWB
