Old 06-16-2007, 09:22 PM   #26
Yankeelights
Yankeelights's Avatar
Re: Dual Exhaust Photos
Looks to me like there are no header mods required. I hope that's how it is!
~ Dave
Originally Posted by benoit454 View Post
Do thoose header buddies require you to cut your exsisting header flange off of the header itself and weld thoose on?
Yankeelights is offline   Reply With Quote
Old 06-17-2007, 12:45 PM   #27
wedgemon
wedgemon's Avatar
Do thoose header buddies require you to cut your exsisting header flange off of the header itself and weld thoose on? or do you only have to cut your pipe/reducer off and weld that on your pipe then it fits up to the back of the standard flange headers?
I know the ball and socket deals you have to cut the headers and the lead pipe and put thoose on. Looks like you only have to do the pipes on that setup and not the headers.
The ball and flange of the header buddy fits into (against) the header outlet and attaches to the header flange. No welding at the header side. I may end up having the ball adaptor welded though.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 06-17-2007, 04:57 PM   #28
Yankeelights
Here's the project at hand:
79 Silverado 10
Currently: 305 2bbl, bone stock; TH350; 3:73; 266,000 miles; single exhaust with a terrible stock cat.
Planned: 406 w/ blueprinted Quadrajet; good ol' Crane Cam; Speed Pro Pistons; 5.7 Rods; tweaked cast iron heads; headers; dual cats; undecided on pipes & mufflers.
Old 06-18-2007, 12:04 AM   #29
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
79 Silverado 10
If that truck is ever to see dirt again copy and modify my setup - headers for a full-size car, S-bent header extensions from Headman Hedders, insert high-flow cats, about 2ft of straight extension pipes, two mufflers of yer choice, then either turn downs or tailpipes out the back. Do everything behind the headers in 2.5 piping, you don't really need 3" unless you have a high-revv big-block to breather fire through it.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 06-18-2007, 05:56 AM   #30
Yankeelights
I'm not sure exactly what you mean by "see dirt again" but she's a daily driver. Do you mean lowering it? Yours is one of the setups that I've been considering.
What will the car headers do for me? Do you mean headers for a 78ish Monte Carlo? If not, then what year & model car?
Will headers made for the 73-87 trucks clear the cross member?
Thanks for the help!
~ Dave
Old 06-18-2007, 04:57 PM   #31
Ivan D.
Ivan D.'s Avatar
Dave, I meant that lotsa folks complain that truck headers actually hang a little too low, which may be fine if it's a strictly street truck but may become an issue when you go off-roading. The car headers I'm aware are supposed to cure the problem are for the '80s Monte Carlo, they are still full length headers but they don't hang as low as the truck ones.
Old 06-18-2007, 07:27 PM   #32
Yankeelights
OK, now I gotcha ... no, it's not much of an off-road vehicle being only 2WD, so I shouldn't have clearance problems. It's main function is hauling stuff to renovate my 150+ year old house. It'll be nice to be able to go up hill with a full load at more than 30 mph one day soon. Thanks again!
~ Dave
Old 06-20-2007, 12:31 PM   #33
lurch115
lurch115's Avatar
you guys with 4x4s are going about it all wrong...to get past the transfer case you have to go up and over it... i put duals on mine 2 years ago and haven't even had so much as a collector gasket go out....i've unhooked the exhaust from the headers twice and reused the same old plain gaskets that come with the headers.....that and if you go up and over the transfer case...you can fit 3" in on it
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 06-20-2007, 03:26 PM   #34
AirMale
AirMale's Avatar
1 more
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
