#26 |
1972 C10 Cheyenne LWB
![]() Join Date: Dec 2005
Ain't that the truth. Welcome to a lifetime of permanent renting.
Update: played with the timing and tried things out b/w 8-14 degrees above TDC. I was never really sure about the marks on the balancer, but I would test drive between adjustments and never reached the ideal balance between pinging and power. Check the plugs and they were fouled and gapped down. Checked the compression and the first 2 holes were at 25lbs! That would explain the grey smoke I've been belching. Valves, maybe rings. Looking at a new motor or a rebuild. I'll post some questions about that next.
1972 LWB Cheyenne C10 350 TurboHydramatic |
#27 |
Re: Timing: Power & Rattle v. No-power & no rattle
Sir, I would consider buying an adjustable vacuum advance. When you replaced the advance unit did you match up the advance rating number? It is stamped on the flat section where it attaches to the distributor. The stock replacement units range from 8 to 28 degrees of total advance depending upon the application. The length of the slot determines the "stroke" of the
arm.The adjustable units are inexpensive and allow you to tailor the vacuum advance to the vehicle. Sincerely, Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 ![]() |
#28 | |
