#26 |
Old member
Re: Thoughts On A Cold Air Set-Up
Here is my setup. I took a caddy airbox and sealed the factory opening and cut a 4" hole in the bottom. I then cut a 4" hole in my raditor support. I bought 2 90 at Lowes and 2 couplings and mounted it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 | |
Happy to be here
![]() Join Date: Mar 2000
Scoti, part of our testing included a modified stock air box vs an intake tube with a open cone filter. We found that by opening the bottom of an air box, and using a panel filter along with some aftermarket tubing to clean up the air flow track I could put as much air in my motor as the $200+ intake tubes could. Here was the set up I built. For those weak at heart, be forwarned these are pictures of Ford motors. Here's your common intake tube with cone filter-
#28 |
Happy to be here
Here is my modified stock air box-
#29 |
Happy to be here
And this is what I did to mod it-
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-22-2007 at 12:04 AM. |
