#26 |
Just like to part out trucks!!
Re: parting 71 chevy 1/2
Don, its in bad shape sorry
Walts here are pics, I cannot find a dipstick or hole for one. Kind of puzzling to me. So your saying since it has a J in it, its not worth anything huh? Oh well I'll just sit it with the others than. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#27 |
pics
#28 |
active member
hello randy , sorry i didn't get back to you sooner. that sounds like a deal for the shifter linkage and brake pedal assm. just let me know where to send the money once you have it out and have figured out shiping. thanks again jim.
#29 |
72 Cheyenne K20, Scott, I got 2 good pair of metal door panels $15 each pair plus hipping
70GMCer, Steve, Let me get the door panel off and see if that stuff is all good. What exactly are you needing for the latch assembly? Toast2112, Jim, I'll try to get it all off Tuesday night but it may end up being Friday night. I got to watch the kids on Wed and Thursday so that ties me up on those nights. Thanks Randy
#30 |
if either one of those sets of door panels are white ill glady buy a set from you if those two dont.thanks
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
#31 |
Sorry, brown and the ones on this truck, the ones on this trucks have a couple coates of paint on them.
Thanks Randy
#32 |
![]() Join Date: Sep 2000
Hi Randy did you get all this # 19J269043 V0527HV from the same spot?
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#33 |
active member
not to worry randy, when ever you get them out will be fine. just give me a shout when you are ready for some money. thanks again jim
#34 |
JDL, Yes Jim,, right where you circled.
Toast, Jim, I'll let you know. Thanks so much, Randy
#35 |
It does have a drivers side dipstick, I found while scraping the pack rat terds off it. Jim, pm'd you my number. No dipstick but the holder is there by the manifold. Thanks Randy
#36 |
Weekend Warrior
Manifolds look to be early "Caprice Classic" Early to mid 80's with a 305cid. I know that they could have been changed. being a Driver's side dipstick it is an early motor. Harmonic balancer is the larger/fatter 6" model usually found on 350's
327's USUSALLY had a real skinny H.B. again, could have been changed. Check the casting numbers and date code on the back of the block - probably an act of congress to clean them off, but that should narrow it down even better with the front Suffix code.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#37 |
sorry, but corvette L79's didint have holleys (nova's did)... and even if they did it doesnt change the fact that the shortblock is the valuable part of this... obviously the heads are not '65 corvette heads would not have accesory hole on the front. it look like someone put later model heads/manifold/ ect on a old 327 block
#38 |
Casting Number, 3970010
CID, 302/350 Years, 69-79 HP, 145-370 Comments, car & Truck 2 & 4-Bolt Most common
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa Last edited by JDL; 07-10-2007 at 06:31 PM. |
#39 |
Code,HV
Year, 69 CID, 350 Vehicle, Impala HP, 255 RPO, LM-1 Trans, TH 350 Carb, 4-Brl Comments, Hyd Cam
#40 |
Weekend Warrior
Just for referance where did this information come from?
#41 |
Thanks for the info Jim!!!
![]() ![]() ![]() I'm still parting this truck see anything you need before it goes to scrap. Front disc set complete $100 rearend not sure ratio yet but will find AT crossmember $30 plus shipping There is more just ask!!! Thanks Randy
#43 |
I was hoping you were right Ed, I've had a local guy come look at it, he said its a good motor but not a vette. Oh welll, I was hoping to get lucky
#44 |
did you actully get the casting number off the back of the motor yet?
i also have had good luck with www.nastyz28.com, although it would be a rare find. |
#45 |
Yes JDL has the block number 3970010. Thanks Randy
#46 |
active member
hello randy money sent, PM sent thanks again jim
