07-09-2007, 11:43 PM | #26 |
Too many projects
Re: Spare Tire?
I have my spare flat mounted in the front drivers side of my bed. I made up a simple bracket mounted to the bed florr and the rim secures through a lug hole with an old lug and stud. But I will be doing the sunken in bed route with a trailer fender when I get the chance to.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" Last edited by lowrollin70gmc; 07-09-2007 at 11:43 PM. |
07-10-2007, 12:35 AM | #27 |
Re: Spare Tire?
I have a spare sitting in my bed under my tanaho cover ( I know I didn't spell that correct) but the best part about my spare is it is flat.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s |
07-10-2007, 01:08 AM | #28 |
Re: Spare Tire?
I don't carry one & have my cell in case of emergency. For road trips, I toss one in the bed along w/my aluminum floor jack. When I get to the hotel, I carry them inside until I'm ready to hit the road again.
I always thought about doing the 'hidden' floor thing. I would raise the entire bed floor since it's needed for ground clearance anyway. Then basically make a 'trunk' under the front of the bedfloor & use the bedfloor as the trunk-lid. Would only be deep enough for a Mickey T 8-ply front runner. But a spare's a spare when it's needed.
07-10-2007, 03:21 PM | #29 |
Re: Spare Tire?
Tire plugs, green slime and a small 12v compressor. That will get you where you need to go and the green slime won't muck up too much. Had to plug and slime my rear bike tire on a ride and I still made it home @ a high velocity.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
07-10-2007, 03:38 PM | #30 |
Junior Member
Re: Spare Tire?
Ok I sell tires and wheels for a living. DONT USE FIX A FLAT OR SLIME!!!! Once you have put either one of these products in your tire you can no longer properly repair that tire, your only option at that point is a plug or a new tire! Get triple a to tow it, or jack it up on the side of the road pull it off hitch hike to the nearst tire shop get it fixed and hitch hike back.
Also the other problem with fix a flat and slime is that thay can actually damage chrome wheels. Some of the chemicals used in these products will etch aluminum if left in contact to long and will begin to cause the chrome to lift and peel. Last edited by bigo181979; 07-10-2007 at 03:41 PM. |
07-10-2007, 03:54 PM | #31 | |
Active Member
Re: Spare Tire?
07-10-2007, 04:52 PM | #32 |
Re: Spare Tire?
I had heard the same thing: 'if you use the fix-a-flat or slime, you can't ever repair the tire w/a patch'. I used to do it w/o issue. You had to basically scour the inside of the tire, especially where the punture was, & then do the repair.
Regardless, fix-a-flat or a small air comp won't do squat if a tire comes apart from a road hazard. That's where the spare is priceless.... unless you don't mind paying to have it towed or don't mind leaving it in the middle of timbucktoo.
07-10-2007, 07:33 PM | #33 |
Re: Spare Tire?
This guy did one on his '64. I think you could do something similiar (I'd stay away from the wood, but it works!)
Good luck, Rg http://www.chevytalk.org/fusionbb/sh...hp?tid/159799/
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
07-10-2007, 08:26 PM | #34 |
never finish start another
Re: Spare Tire?
Put run flat tires on. There are thousands of vettes on the road with no spares
07-10-2007, 09:50 PM | #35 |
Re: Spare Tire?
Well mine has a spare in the bed but it is flat and doesn't hold air and I don't have a lug wrench in the truck or a jack. So a few things I need to work on. But first I need to get the new wheels and lowering kit on.
The S10 has a mini spare in the bed loose and jack in the stock location for now.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
07-10-2007, 11:53 PM | #36 |
Noobie McNoobster
Re: Spare Tire?
Anyone know what junkyard vehicles would be good possbile donors for the original style under bed spare tire mount?
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
07-11-2007, 01:01 AM | #37 |
Long Fleet Club
Re: Spare Tire?
the SSR has no spare also
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
07-11-2007, 01:15 AM | #38 |
The Original HotRod KnifeMaker
Re: Spare Tire?
I got the same answers when I asked this a few months back. I just don't feel good about NOT having a spare. Here is my solution- I still need to pick up a cover for it, thinking about one of the older style hard 'continental' types.
I just bought one of the standard carrier brackets and bolted it in place. The Jack and lug wrench are bolted up against the tire.
Dave 69 GMC SWB 2WD 454 Turbo 400 |
07-11-2007, 01:34 AM | #39 | |
Re: Spare Tire?
I heard that tire repair guys don't like that stuff .... didn't know if they were giving me hype or what. Thanks for setting me straight. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
07-11-2007, 02:29 AM | #40 |
Re: Spare Tire?
This looks good for a 4x4.....not too sure about a lowered truck.
http://www.stylintrucks.com/parts.as...tfamilyid=1770 Will a mini tire fit behind the seat? |
07-11-2007, 11:58 AM | #41 | |
Junior Member
Re: Spare Tire?
07-11-2007, 12:31 PM | #42 |
Active Member
Re: Spare Tire?
Thats why I buy Discount Tire free flat repair.
07-13-2007, 10:48 AM | #43 |
Re: Spare Tire?
Things are really different here where I live. Plugs are almost non existent. You can ask to have it done and most shops will refuse to do it. The way they fix a flat is to take the tire off and patch it from the inside. Cost about $25.00 bucks.
esll.
07-13-2007, 10:58 AM | #44 |
Junior Member
Re: Spare Tire?
We base it off the condition of the tire, if it is an old tire that has begun to crack or has very little usable tred life left we will plug it, otherwise we patch it. Unless of course it has fix-a-flat or slime in it.
