Old 07-26-2007, 05:52 PM   #26
flintc10
Re: Looking for pictures of swb with air ride
So if you install a bolt on c notch from Air Ride. You have to cut your bed? Could someone clairify this for me. Thanks
flintc10 is offline   Reply With Quote
Old 07-26-2007, 05:55 PM   #27
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
you cut your frame for a C notch
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-26-2007, 06:43 PM   #28
72highlander
Sophomore Member
72highlander's Avatar
i know you were wanting short trucks, but mine has a c-notch only and has a wood floor bed. it has dropped spindles with the bags up front and 2 inch blocks as well as bags in the rear. if you air out the rear completely, the pumpkin will touch the bed floor. hope this helps. last pic is at ride height.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 07-26-2007, 09:17 PM   #29
Tim Christian
Tim Christian's Avatar
Here is my sons truck!
Tim Christian is offline   Reply With Quote
Old 07-26-2007, 11:35 PM   #30
fastom
That's right, it's Copper!!
fastom's Avatar
Tim, who makes the bed cover on your sons truck.
fastom is offline   Reply With Quote
Old 07-27-2007, 04:27 AM   #31
Tim Christian
It is made by Checker Products in Benton, KY.
Old 07-27-2007, 10:32 AM   #32
piecesparts
Parts and more parts
piecesparts's Avatar
This one is a local truck that made it to the front page opf Custom Classic Trucks. It has an Air Ride suspension.
piecesparts is offline   Reply With Quote
Old 07-28-2007, 01:51 AM   #33
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
My ongoing Project..... on the door with 22"s
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-28-2007, 07:44 AM   #34
see ten
WTB this ad
see ten's Avatar
Anyone ever thought of "shaving" the top of their diff for bed floor clearance on these milder setups? And when I say milder I mean the guys wanting all the drop they can get without the diff coming through or impacting the bed floor. The 4x4 guys have been doing this to the bottom side of diffs for some time now for the extra ground clearance.
see ten is offline   Reply With Quote
