Old 10-02-2007, 03:11 AM   #26
68K20 x Drill
Re: 1968 GMC C2500 4 spd V8
That is an interesting back bumper, looks like it could make quite an impression.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-02-2007, 03:32 AM   #27
earl87gta
earl87gta's Avatar
Speedo is machanical sounds like the cable is broke time to spend the $12 bucks for a new one. the rest of the gages are elcetrical so how bad is the wireing under the dash hacked up. you may be better off finding a under dash harness from some one on the board or buying a new one. The boody looks to be in good shape you have a great project there.I cant remeber how the fuela sending wiring was ranin the trucks but its possible it broke some were I would folow it back from the tank to the dash and see if it is cut some were.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-02-2007, 11:06 AM   #28
Yukon Jack
Post Whore
Yukon Jack's Avatar
I hate tracking down electrical issues! Good luck on that project. On both of my trucks I went ahead and went with new wiring harnesses for the engine compartment - mine were so brittle on the K5 that I knew it was a wise decision plus they aren't too expensive. The under dash new harness is unfortunately pretty expensive. Hopefully you can find a simple problem or just replace with a good used harness. Not a bad idea to splice in a new 4 wire line from the firewall to the rear lights - they get pretty bad from rubbing on the frame.
The truck has lots of potential after you get through the initial problems.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-02-2007, 01:37 PM   #29
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
thanks guys and yeah it does.,....runs awesome now that i got a lot of the old fuel out. I also hate wiring/electrical games with vehicles. Im just glad it doesnt have a nice big wiring thing like new cadillacs and high end cars with all the little toys.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 10-03-2007, 03:21 AM   #30
earl87gta
earl87gta's Avatar
Good to here its running good. It’s nice not having a lot of wiring to it. Sent you a PM.
Earl
Old 10-04-2007, 12:09 AM   #31
ProStreet83C10
Drag Racer
got the PM thanks, will see what i can do with wiring before i buy a new harness....if you find a good one keep it for me just in case....
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-04-2007, 12:27 AM   #32
earl87gta
earl87gta's Avatar
did you get the speedo working you should be able to replace the cable with out taking the dash or any thing apart. they usaly strip out on the transmition side of the cable.
Earl
Old 10-04-2007, 11:24 PM   #33
ProStreet83C10
Drag Racer
havent gotten that far yet.....replaced valve cover gaskets tonight and worked on rear lighting wiring.
Also need to replace something in the shifter because we are able to like pull the shifter out of the transmission and thats not right at all.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 10-04-2007, 11:29 PM   #34
1970bowtie
1970bowtie's Avatar
Originally Posted by WorkinLonghorn View Post
Looks like an orginal V-6 "M" code. That engine is a transplant.
I like it,and for THAT price? Nice score.
What does it show on the sticker inside the glove box? - Brian
i have a truck thats identical to that, with the 305 six banger in it
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 10-10-2007, 09:21 AM   #35
1987_3/4ton_chevy
Cowboy Up
We got the shifter to stay in the transmission last night. Also, any ideas what to do with the back tail lights? We re-wired it from the hood on back to the lights.... what else should we look for?
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 10-10-2007, 11:54 AM   #36
caminokid
Chevy nut
caminokid's Avatar
I have that same back bumper! It rusted all to you know where. I am changing mine out this weekend.
I didnt think I would ever see one of those again.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 10-10-2007, 12:28 PM   #37
earl87gta
earl87gta's Avatar
It has to be in the wiring from the fuse block to the switch. I cant remeber but does the switch has seprate inputs for the tail lights if it does to could change it. I would start witht he fuse block theck the tail light fuse it may be a rusted socket you may have to clean it up some. seams like I remeber my 67 having that trouble once and all I did was sandpapered the fuseblock conection.
Earl
Old 10-10-2007, 01:16 PM   #38
1987_3/4ton_chevy
Cowboy Up
thanks dude, i will check that when i get time to look that over.... thanks
Chris Cary
Old 10-10-2007, 05:41 PM   #39
earl87gta
earl87gta's Avatar
Any time I hope it helps
Earl
Old 10-10-2007, 08:07 PM   #40
1987_3/4ton_chevy
Cowboy Up
what do you mean by that?
Chris Cary
Old 10-11-2007, 12:44 AM   #41
earl87gta
earl87gta's Avatar
I just hope I’m not sending you on a wild goose chase and have you later find out it was a bad ground or something.
Earl
Old 10-11-2007, 11:59 AM   #42
1987_3/4ton_chevy
Cowboy Up
oh i see, its ok i am bring down my truck i think to the central IA BBQ thing on a trailor so you know... more people can pin point the problem i think and hope. thats my plan atless is to bring it down
Chris Cary
Old 10-12-2007, 11:09 PM   #43
1987_3/4ton_chevy
Cowboy Up
Well guys, we started taking off the paint and almost one whole side is completed!! Pictures will be posted soon.... keep you all updated!
Chris Cary
Old 10-26-2007, 10:22 PM   #44
1987_3/4ton_chevy
Cowboy Up
Well my duddy stopped over and helped scrape the paint off and almost the whole right side is done.... getting closer but need more money lol.
Chris Cary
Old 10-26-2007, 11:31 PM   #45
67_C-30
I have a radical idea!
67_C-30's Avatar
Don't hate me, but you look just like the dude in the Goody's Commercial!
Nice rig, though!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-27-2007, 12:19 AM   #46
streetstar
streetstar's Avatar
that looks "rust free" for an Iowa truck --- cool deal Lucille
streetstar is offline   Reply With Quote
Old 10-27-2007, 08:20 AM   #47
dave3156
Looks like a great truck to work on. the speedometer problem could be the plastic gear in the transmission. These are notorious for breaking, might want to check it before you just replace the cable. They are pretty easy to replace too. Good luck and have fun!
dave3156 is offline   Reply With Quote
Old 10-27-2007, 09:01 AM   #48
Bucky71
Cool truck. What's this?
Bucky71 is offline   Reply With Quote
Old 10-27-2007, 12:44 PM   #49
1987_3/4ton_chevy
Cowboy Up
First off, thats not me in the photo... my friend was being a Smart A**
Chris Cary
Old 10-27-2007, 12:45 PM   #50
1987_3/4ton_chevy
Cowboy Up
Whats what?
Chris Cary
