Old 07-18-2007, 03:28 PM   #26
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Backfiring
Good eye jhow66. That will make a lean condition for sure.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-18-2007, 04:00 PM   #27
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: Backfiring
True, but most people put the vacuum line back on when they re-install the air cleaner.
Even with the hose off, it will never keep a good running engine from idling or cause a hesitation.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 07-18-2007, 04:28 PM   #28
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Backfiring
If you still want the rebuild kit you will probably have to take the carburetor off and bring it to AZ. There are numbers on it in a few places. They will have to cross-reference those numbers until they find a carb rebuild kit for it. I work there. (part time)
LOW DOUGH is offline   Reply With Quote
Old 07-18-2007, 04:39 PM   #29
prg machine
prg machine's Avatar
Re: Backfiring
Check for sure that if you put the correct gasket under that carb. I rebuilt a Quadra years ago and used one of the 15 gaskets in the kit that was wrong!!! Changed it and it cured it. Spray carb cleaner around the bottom of carb at idle and if it smooths out, you have a leak.
prg machine is offline   Reply With Quote
Old 07-18-2007, 04:47 PM   #30
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Backfiring
I think you can get a base gasket in the chrome aisle (maybe aisle4) also known as the aisle with all the other stuff you don't need like.... Oh I don't even want to say (rice burner stuff). It would be a Mr. Gasket one I think. Gasket between intake and carb
Old 07-18-2007, 09:32 PM   #31
jhow66
jhow66's Avatar
Re: Backfiring
Never saw that line hooked to the air cleaner before. It has full time vacumn so what will it be operating on the air cleaner? The vacumn line that feeds the air cleaner goes thru a water temp switch off the themo housing.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-19-2007, 06:34 AM   #32
68speedalert
Semi-Senior Member
Re: Backfiring
Oops....showing my ignorance of big blockness.
I was remembering small blockness, maybe even newer big block models.
It will operate the vacuum motor that draws intake air from the pipe that drops down to the exhaust manifold shroud. On small blocks, it will go to a temp sensor mounted in the air cleaner, which regulates vacuum to the motor mounted in the snorkel of the air cleaner housing.
Still won't affect idle much on a good running engine.
Sorry for the incorectness...
Old 07-19-2007, 09:51 AM   #33
Billla
Billla's Avatar
Re: Backfiring
Pyro, are you posting the same question under another thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=250187
Billla is offline   Reply With Quote
