Old 07-22-2007, 10:28 PM   #26
jkade
jkade's Avatar
Re: A few updates on the 67
Go for the 4.8/4l60e! Man that thing looks sweet. What's in the plans for the Blazer,... you must be Porterbuilding something,... hmmm,...
It is going to be different I would rather have a procharged 6.0 in the blazer.
jkade is offline   Reply With Quote
Old 07-23-2007, 02:47 AM   #27
mexgrhd68
mexgrhd68's Avatar
Originally Posted by jkade View Post
Rear is a 6" spring with a 1" block and the front is drop spindles with cut factory springs.
how many coils did you cut off the front springs? and also, do you have a c-notch? rear shock relocators? longer trac bar?
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 07-23-2007, 02:10 PM   #28
jkade
jkade's Avatar
The front coils came off my blazer as all the parts did. When I bought the blazer the coils had already been cut and I added the drop spindles. I don't have a c notch but that will go in this weekend since the rearend is sitting on the bumpstops now. I used the bottom relocaters and left the factory top shock mounts in place which I may change later. I have a adjustable trac bar also. One thing I have ran into in lowering this truck as much as I have is the driveshaft is too long now, I had to take the caps off and slide it in the yoke and then put the caps on to get it in. I am going to fix that this weekend when I move the whole rear suspension back 1 to 1.5" and that should make the tire to wheel well center a little better, I think that is something that everyone should do when lowering one of these trucks. The truck now has drop spindles and cut springs on the front with 72 suspension, master, booster and I am not running a factory porp valve and using a adjustable porp valve just on the rear brakes. The rear has new 3:73's, easton posi, 6" springs and a 1.5" block, adjustable bar, and disc brakes. I may in the near future install a stock 4.8 and a 4l60e.
