#26 |
Out of the carpool lane.
Re: longbed to shortbed conversion
Roman, you have nothing to worry about regarding the crossmember and trailing arms- I had the same thoughts when I did mine, but it fits correctly if the frame is cut correctly. It's hard to explain, but it'll work with no other mods needed.
You'll need to shorten your driveshaft or (preferably) just make a 1-piece shaft and delete the carrier bearing.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#27 |
Brad, thanks for the reassurance. I'm restoring the bed and floor right now. Next month I'll play with the chassis. Thanks for the tip.
#28 |
That is how the crossmember is on the shorts from the factory. It will clear fine. You will need a shorter driveshaft. Here is a linky for one.http://cgi.ebay.com/ebaymotors/Custo...spagenameZWD1V
#29 |
yeah you gotta remove the front bend mounts, completely cut those off... then remove the rear cab mounts and mount them twelve inches back from the stock position.......
#30 |
Ram-Man, you did a cool job on the chassis. Thanks for the photos! Any hard lessons learned?
#31 |
Jandones, what do you mean by twelve inches back from the stock position? Would that be twelve inches from the end of the frame?
#32 |
![]() Join Date: Aug 2005
