Old 07-29-2007, 02:03 PM   #26
71tahoe
71tahoe's Avatar
Re: Will this work? (or miserably fail)
This is what I wound up doing on my son's truck.
Got rid of tabs on the driver's side of the tank and rounded one end of the square hole with a dremel
Drilled and tapped an aluminum plate 7/16-14. It doesn't show it but the final assembly got nuts on the back to lock the bolts
1 1/2" spacers
Had to drill 1 extra hole in the side of the frame for the forward j-bolt. I used an old inner tube from a 26" 10speed bike between the frame/tank/straps
I think next time I'll get rid of the tabs from both sides and insert a long bolt down through the frame on the passenger side, tighten the straps and lock with a bolt on top and bottom of the strap. The j-bolts were a real pain.
71tahoe is offline   Reply With Quote
Old 07-29-2007, 02:12 PM   #27
timcos
Chief Honcho In Charge
timcos's Avatar
Exactly why I have my truck in an LLC. Among other things.
Privay and Asset Protection. The only remedy is the insurance pay out. Exactly where I want them to go.
I can't stand being batted around like a toy.
Originally Posted by Longhorn Man View Post
in your state, I would too. if it doesn't have a DOT certification number for that model number vehicle, the laywers would have fun batting you around like a cat with a ball of yarn.
Same thing if someone gets hurt from the fuel after rear ending you.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 07-29-2007, 03:16 PM   #28
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
71Tahoe: Is it just the camera angle, or isn't that tank low enough that a flat (especially a blowout) will put the tank bottom onto the pavement ???
I'm planning a rear tank, too, but it looks to me like it really HAS to be mounted higher up to the bottom of the tank than an imaginary string-line drawn bewteen the two rear wheel rims, or a flat on one (or Heaven forbid, both) of the rear tires would cause you to drag the bottom out of the tank, while you're also making lotsa sparks.
A bad combination...............
68shortstep is offline   Reply With Quote
Old 07-29-2007, 04:46 PM   #29
72highlander
Sophomore Member
72highlander's Avatar
the only way a blowout would cause the tank to drag is if you drove it aired out. right now the axle is nearly against the frame, which i doubt that he will be driving at that height.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 07-29-2007, 05:38 PM   #30
71tahoe
71tahoe's Avatar
It's on the bump stops with about 2.5" clearance. It "should be" about 4-6" higher at ride height but he's only 17 and knows everything (already planning a skidplate when he needs to be planning not to have to use it). When it's done, whatever he tears up he has to fix. (I will require an extinguisher though )
Old 07-29-2007, 08:33 PM   #31
MisterE72
Keep Your Nose Clean
Check it folks. I took 71tahoes idea ( )and modified it a little. I'll let the pics do the talking. Will this work of miserably fail?
MisterE72 is offline   Reply With Quote
Old 07-29-2007, 08:38 PM   #32
MisterE72
What a jackass...I forgot the pics.
Old 07-30-2007, 07:22 PM   #33
MisterE72
I forgot to mention, I'll be replacing the bolts I used with fully threaded bolts. The front side needed a tad more to fully level with the frame.
Old 07-30-2007, 09:40 PM   #34
71tahoe
71tahoe's Avatar
That looks like it'll work. You might want to put nuts above the straps too when you get the fully threaded bolts. That way the lockwashers will compress.
Old 07-30-2007, 10:43 PM   #35
MisterE72
Thanks for posting your pics and for the advice (everyone's). I'm buliding this truck for my now 4 year old son too. I'm hoping he'll treasure it as an adult. That is why I want to make sure my build is clean as well as safe. Thanks again.
Old 07-30-2007, 10:49 PM   #36
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I wouldn't bolt it to the frame then. Strapping it is the only way to go. I realy mean only. If you bolt it to the frame in any manner, you are bolting something that isn't flexible to something that is and will flex. Straps or not, the tank will fail. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-30-2007, 11:00 PM   #37
MisterE72
Happy to hear from you Wes. My tank came with no mounting instructions. Can you post them please? My blazer conversion kit only came with one pair of J-hooks and the straps. I'm in aw as to how to properly mount it. I've seen other threads, but most useb materials not inclued in the kit. Thanks again Wes.
