#26 | |
Re: bed wood
#27 |
Re: bed wood
A good idea after you blow the wood down with air is run a tack cloth over it, there will still be some residual dust if you don't. I have seen both applications on oak and pine (brush and HVLP). I have always believed a brush will give a better coat and the chance of stirring up dust is minimal. I build custom furniture as a hobby and I always apply a sanding sealer on the woods I use and sand between coats, mainly to etch the suface for the next coat of sealer to adhere too as well as take care of any imperfections in the application of the varnish.
The wood beds are beautiful, unfortunately my '69 is a worker bee.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#28 |
Re: bed wood
I finished bed Saturday it took a solid 9 hours to do. i Put 4 coats of spar varnish and sanded with 220 in between coats on Friday. I put new cross sills and a new reinforment sill, i was lucky because neighbor was able to help here and there could not have done this by myself. again 9 hours to put all new wood in had a hell of a time it was one of the hardest things i have done. Thanks for your help oh yea my bed looks great it turned out real nice.
#29 | |
Active Member
Re: bed wood
#30 |
Junior Member
Re: bed wood
If your truck lives outdoors be sure to touch up the varnish every year or so. We didn't on my wife's truck and eventually the wood got ruined.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
#31 |
Re: bed wood
OK, before you guys let anyone else brush, spray, dip or apply anything onto thier bed wood. Please have them check out the 2 year test that Mark-K did on various common bed wood products (they used both Pine and Oak too).
http://www.mar-k.com/final_summary.html I opted for the Por-15 product called "Plecid" and applied 3 coats with a foam brush and man you wouldn't believe the finish. It actually looks like water is sitting on the wood. Problem is the "Plecid" doesn't have any UV protection so they used Minwax Gloss "Helmsman Spar Urethane" as it has one of the best UV protection on the market. So far I have not finished my bed wood as yet (just on a 1 foot long sample of the Red Oak I'm going to use) because I'm trying to hurry and get my motor installed befoe the snow flies. |
#32 | |
so easy a caveman can do it...
![]() Join Date: May 2006
Re: bed wood
Not really...I'd recommend sanding 80, 100, 120, 150...220 if you're really insane ![]() ![]() Last edited by Sequoyah; 09-18-2007 at 10:52 PM. |
#33 |
Orange Truck
![]() Join Date: Jun 2005
Re: bed wood
Suggest that you use a high quality marine varnish and apply three coats. The varnish is somewhat expensive ($30), but is worth it in the long run. I did somewhat like you are doing. Purchased the wood oak wood package from Mar T? (Oklahoma City) already drilled and grooved. When over it with the finest of sand papers thoroughly. Applied the marine varnish and topped it off with polished SS strips and fastners. If your model had the heat shield, I would suggest installing it too. Hope this helps.
#34 |
Re: bed wood
![]() Any updates? ![]() |
#35 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: bed wood
The property you describe is called 'mill glaze'. The planing and sanding of wood causes the grains to lie down, preventing proper penetration of finishes or later, after the finish had been applied, those grains can relax, affecting the integrity of the finishes adhesion. The water method works well plus there are "mill glaze removers" available at most better lumber yards. ...just my .02 worth. |
#36 |
Keepin it runnin!
Re: bed wood
WOW! That Flatbed is awesome! Beautiful Workmanship!
Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
#37 |
Re: bed wood
mar-k did a study where they compared several different types of finishes on different types of wood over 2 years in the elements. it's on their website
and i just saw that someone else said the same thing.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. Last edited by GMCBubba; 10-19-2007 at 09:20 AM. Reason: stupid |
