#26 | |
![]() Join Date: Nov 2002
Re: restoring bolts
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
#27 |
Re: restoring bolts
Black oxide and cold blue are two different chemicals/processes. I have never done cold blue so I am unsure of the rust preventing properties. I know black oxide works fairly well. If you do blue them post some pics please.
#28 |
Re: restoring bolts
Like I said, I did the cold bluing on an old .22 rifle a long time ago. It turned out okay. It really turned out more black oxide looking than it did "gun blue".
I have been working on bolts, nuts and washers for my '67 for what seems like months. It's probably only weeks. lol I've been trying to keep everything segregated to where it goes. Lots of bolts to keep track of. To me, the details -like the bolts, etc., are what makes or breaks a build like what I'm doing. On a side note, where is the best place to get new OEM type bolts - coating and all? I've been doing some work on my old '66. On the top of the fenders there are semi-bright colored, washer-head, hex-drive bolts/screws. I'd like to get new ones - just of those. The rest of the ones that I fiddling with are black oxide coated. I can deal with those. Maybe they're cad plated. I don't know for sure.
#29 |
Re: restoring bolts
I got the bolts and clips for the inner fender to fender from GMC Pauls. I think I've seen the complete front bolt kits both stainless and regular on EBAY. I use zip lock bags with paper in them stating where they go written with a sharpie marker. On more complex issues I'll take a few digital picture for looking at later. Black oxide is real easy, you mix the solution with distilled water and put the clean metal parts in it for a while. If I see the ebay add I'll link it.
#30 |
Re: restoring bolts
I would be very interested to know the chemical composition of the Quick Black. If you can't find out Esll I'll try researching it on the web and see what I can dig up. Cheers
71 GMC 1500 LWB |
#31 |
Re: restoring bolts
I found this neat little article on using the black oxide finish.
http://www.joesfalcon.com/nutsbolt/nutbolt2.html And this place has a 1.25 gallon kit for $42 or a 2.5 gallon for $80. The 1.25 gallon kit is similar to Eastwoods. http://www.caswellplating.com/kits/black.htm Eastwoods: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT I think this is the way I'll go when I get to that point. Last edited by 1972CheyenneSuper; 10-04-2007 at 06:49 PM. |
#32 |
Re: restoring bolts
Those products seem perfect. The more I think about it the more applications I can come up with...hood hinges, brake pedals, hood latch ,striker plates.
Diluted Muriatic acid apparently makes a great rust remover/metal cleaner to prep the bolts or what have you,but if you're not familiar with this acid...full eye, hand, face, you name it protection.
71 GMC 1500 LWB |
#33 | |
Re: restoring bolts
Sorry Spoof got busy but here it is ..... Quick Black = Selenioust Phosphoric acids. esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 10-05-2007 at 02:35 AM. |
#34 |
Re: restoring bolts
Looks like I'll be looking for a vibratory tumbler and some black oxide solution!
#35 |
Re: restoring bolts
That's great Esll. Now I'll see if I can hunt some of that down. According to the Eastwood oxide system it's a "temporary" agent good for about six months...probably the most you can ask from any product once exposed to the weather any how.
71 GMC 1500 LWB |
#36 |
Re: restoring bolts
[QUOTE=Spoof;2389248]That's great Esll. Now I'll see if I can hunt some of that down. According to the Eastwood oxide system it's a "temporary" agent good for about six months...probably the most you can ask from any product once exposed to the weather any how.[/QUOTE.
********************************************************** I can not comment about Eastwood's system as I have not had the opportunity to use it. I can only say that the Quick Black that I have used last's a lot longer then 6 months. Next time your at the wreckers open doors, hoods ect. and look for bolts and you will find that they hold up quite well. To go to the effort to restore bolts and such items would be excessive in the restoration sense to winter drive such a vehicle. With that thought in mind I think you will be happy with the product that I posted. The library has references for basic plating that might be of interest to you. esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
#37 |
Official Site Guitar Shredder
Re: restoring bolts
i put mine in a maritic < spell acid and water mix, give it like 5 hours and they are good to go, rince them very well and coat in used motor oil. i have also used tranny oil just the threads......after they soak for a while i clean the access oil with laquer thinner then lightly prime then paint.........then i clean all access threads with a wire brush, and re oil.... never had a problem with this process ever..............hope this helps tony
#38 |
1968 Custom Camper
Re: restoring bolts
After using muratic acid to clean the part - rinse the item with TSP (Tri-sodium phosphate). It neutralize the acid and is a cleaner. TSP is a very common household cleaner and can be bought in a powdered form almost any where.
#39 |
Re: restoring bolts
#40 | |
Re: restoring bolts
#41 |
Re: restoring bolts
any body got more on the muriatic acid.
would like to just use its for a off roadin truck. so i dont care what they look like.
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
#42 |
Junior Member
![]() Join Date: Mar 2007
Re: restoring bolts
if they are rusty you can try electrolysis...
http://frontstcycle.blogspot.com/200...t-removal.html http://frontstcycle.blogspot.com/200...l-is-good.html
frontstreetcycle on Instagram Last edited by scrapmetalart; 12-01-2009 at 03:58 AM. |
