Old 01-27-2008, 02:59 AM   #26
mrein3
mrein3's Avatar
Re: What welder to weld floor and body panel.
Originally Posted by wibilly View Post
one thing i never see mentioned is duty cyclewhen this subject comes up.well the smaller cheaper welders do work they have a very limited duty cycle, meaning that they will be ready for a break even before you. i also agree that if possable get a welder with infinit amprage controal rather than just 2 or 4 heat settings, you will be glad you did. as said before get the best you can afford
I took a couple of adult continuing education classes on welding. In the classroom we used a lot of Lincoln products. I don't know the model number but one day I was using a 220V Lincoln machine. I was welding thicker sheet metal, around 14 gauge. After about 1 inch of bead, the machine shut off. I hit the duty cycle. What wibilly is talking about is how long a machine can run at higher outputs.
I don't know what the specs are for that machine I was using that day but lets use a 50% duty cycle as a for instance. 50% duty cycle means that out of a 10 minute period, you can only use that machine for 5 minutes.
So now you paid $600 for a power source and it only has a 50% duty cycle. You're welding up that whizz-bang car hauling trailer out of super mega thick steel. You got your power source cranked up to just about its max output. You start a bead. Now every minute you weld, you have to wait a minute for the machine to cool off.
Long story short, I bought a Miller.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is online now   Reply With Quote
Old 01-27-2008, 04:04 AM   #27
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Here's a shot of our Hobart 110 mig welder. We've used it on two 55's a two 71-72 chevy trucks.....its been a great welder. We use argon. Dont know what wire we use.
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-27-2008, 09:23 AM   #28
dingo_dan_22
dingo_dan_22's Avatar
I bought a Lincon 180C. 230V w/ gas. Worth every penny. Remember if you go with a 230V machine you'll need to do some wiring.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
