10-31-2007, 06:37 PM | #26 |
Thread Killer!
Re: Using glove box door for gauge cluster
QUOTE=dukes69;2403592]would like to see more pictures of the finished product if anyone has any.[/QUOTE]
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
10-31-2007, 10:53 PM | #27 |
1969 Short, Fleet, and Beat
I never knew that. Pretty cool and looks nice.
10-31-2007, 11:27 PM | #28 |
would like to see pics of the back side also with the guages installed before and after.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
10-31-2007, 11:28 PM | #29 |
fabricator of anythng not wood
i used the golebox door, idid mine by removing the inner sheet and cutting a relief for the column big enough that the stock rubber gromet fits into it, then i welded small bolts onto the back in5 places then i trimmed most of the outer sheet out of the middle so that i could put my polished bronze sheet with guages onto that,i covered that outer ring in leather, i moved the switches elsewhere on the dash
11-01-2007, 08:10 AM | #30 |
I am using one for the ignition, headlamp and wiper switch.. Went with a 57 truck cluster in the middle..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
11-01-2007, 10:09 AM | #31 |
Questionable
very cool idea w/installing the IGN/key in the console!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-17-2007, 11:51 PM | #32 |
Questionable
So, I'm still really curious how people are doing this - how are you rounding out your edges on the holes you're cutting out? Obviously, you can't roll out or fold over the hole.
How are you going about flush-mounting your gauges?
11-17-2007, 11:52 PM | #33 |
Questionable
Also - anyone have an accurate CAD drawing of the gauge cluster? I measured it all out last night, so I could throw one together, but I hate reinventing the wheel.
11-18-2007, 05:48 PM | #34 |
River life......
I cut the rolled lip on the back side of the door, that way I only had a single panel to deal with. I used the stock nut plates to mount the panel.
11-18-2007, 06:44 PM | #35 | |
A guy with a truck
Does that make sense at all? It does in my head, but not sure how it translates to type...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-19-2007, 03:16 AM | #36 |
My plan is to use mount the gauges inside tubing and then weld the tubing to the panel. Takes a little more time and fabrication experience though.
For the glove box I'm going to weld studs on the backside. I don't think it will be too hard to reach the top bolts; if it is I'll weld in new attachment points to the dash in a better spot. I think you have to trim the dash around the headlight and wiper switches because it protrudes there but its been a while since I looked at it I've haven't seen a real nice way of mounting the headlight and wiper switches yet (not a fan of stock) and I need to find some nice leds for turn signal/high beams chosn 1 I like your dash with the leather and brass, but I gotta ask why is that gauge still on the A pillar? Last edited by TravisH; 11-19-2007 at 03:19 AM. |
11-19-2007, 09:17 AM | #37 |
You could always mount yout switches in the lower return lip of the dash. They would be out of direct sight but still visible if you look down and very easy to reach. You would half to do a small amount of trimming since you have the dash reinforcment bar running along that edge. This way they all would just pull down to turn on and up for off. I did this back in the 80's when we were all into custom bug's
Now as far as these dash's being set up for RHD as well I have to disagree. They are very close with the cluster and glove box door being the same shape but that is about it. The two opening hole are way off as far as needed tabs and returns for mounting. Cluster has provisions for your switches that are raised up a bit and mounting hole tabs. The glove box has one tab in the upper left corner for a switch/button (?) ,then the hole in the right side for the stop arm as well as a larger botom lip for the hindge. Not to mention the needed suport for the column that is built into the reinforcment bar. Sure it can and has been done but not as simple as it has sounded. Did they ever do this and sell them over see's? I have only seen one guy that was building his own truck for Australia (sp?) but never saw it finished. All the other ones I have seek over see's are those strange LHD set up's Kevin LFD Inc. |
11-20-2007, 10:55 AM | #38 |
to answer your ? TravisH that guage is an exhaust gas temp beacause im running upto 80 psi of boost and i need that one right in my vision so that i dont have a meltdown from pulling too hard for too long, that 57 cluster in c10addicts really rocks tho!
11-21-2007, 11:13 AM | #39 | |
Questionable
There is an uncanny amount of symmetry in these trucks. It has to be intentional. GM was on the ball back then. I've seen two LHD trucks from the UK already, and someone on here either purchased or linked to a fleet truck in Switzerland that was used for mountain rescue or a fire department or similar. If they weren't sold over there, they surely made it over there easily enough.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-21-2007 at 11:15 AM. |
07-27-2008, 09:44 AM | #40 |
Junior Member
would anyone have a picture of what is need to cut on the back side.
1968 chevelle ss 396 4spd 1969 chevy 4wd 350 4spd 1970 chevy c10 long box 1970 GMC 4wd long box |
07-27-2008, 04:54 PM | #41 |
I used a air cut off tool. I still have more to do, I need to mount the lights and wiper switches and I need to finish the face.
07-27-2008, 09:22 PM | #42 |
chevy truck fan
fastfun,
that looks very good. i am interested in seeing it in person. maybe one of these weekends i can come over & "bench race" with ya (lol) i may pm you this week to see whats up... rodstored-72 |
12-04-2008, 02:22 AM | #43 |
6>8 Plugless........
Do you have any pics with it installed? It looks very nice!
12-04-2008, 04:30 AM | #44 |
Do you got pics of the outside of the truck from your post shifty
12-04-2008, 11:43 AM | #45 |
Here is one for you that is almost done. http://tennesseeclassictruckclub.com...=asc&start=500
Earl 68 2500 4x4 GMC Burb |
12-04-2008, 12:02 PM | #46 |
Rods
I think it would look good to use a car colomn from the late 70's or early 80s with all the combo swithes on the cololmn then you would just have a clean dash headlight and wipers would be on the colomn.
12-04-2008, 12:21 PM | #47 |
Active Member
12-04-2008, 01:24 PM | #48 | |
80 psi? 80? |
12-04-2008, 05:38 PM | #49 |
I am guessing he may have a diesel in this rig? My cummins ford will burry my 60psi gauge and this winter it will be reworked and have twins capable of 80+psi of boost.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-04-2008, 08:08 PM | #50 |
Sweet!!!
