Old 10-22-2007, 12:08 PM   #26
SkylineNXS
SkylineNXS's Avatar
Re: Same work, new place...
Hey guys, been a while. Did a little more work, got the bed wood installed, after failing a few times and knocking the whole bed off causing a little bent sheet metal due to me not putting at least a few bolts through to hold it on, stupid really....Got it together though, had to rewire the rear lights cause when the bed fell the wire was destroyed by the end of the frame. Some pics of the bed, then also painted the bumper a little different, grille is next, got the rest of the "exhaust" on. Had to put a few pieces together with some bandage stuff to actually not leak all over, im sure it will anyway, but o well. The exhaust was pointed right at the axle before, so i put on the old piece to run it out past it and to the side. Also some pics of my helper...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 10-22-2007, 11:19 PM   #27
badriand
badriand's Avatar
That plywood looks kind of like waffer board to me, be sure you get it really painted up good. When waffer board gets wet it is pretty much useless. On another note truck looks good, i like the headlights and the paint job looks like a good one.
badriand is offline   Reply With Quote
Old 10-25-2007, 12:31 AM   #28
SkylineNXS
SkylineNXS's Avatar
THe plywood is actually 3/4 inch subflooring with a tongue and groove down the center. I put 2 coats of undercoating on the bottom and sides and then marine varnished the top, so i think it should be alright, at least i hope so. I dont plan on drivin the truck in the rain yet anyway cause i havent found all the leaks throught the firewall and all the tiny ones that can plague a truck, so until i do that its gonna be a garage queen on the rainy days, like today...lol. Thanks...night
BRAD
Old 10-25-2007, 10:21 PM   #29
badriand
badriand's Avatar
Maybe your good then, as i have learned the hard way just about everything i do. Just hated to see all that hard work go ....
Old 10-26-2007, 01:45 AM   #30
SkylineNXS
SkylineNXS's Avatar
I agree with ya, these are my first project rucks and im tryin to make sure i dont have to do stuff twice, however lately its been like that, wiring, turn signal switch, bumper, grille, but those ar far easier than the bed, thanks for the comments...
BRAD
