#26 |
Re: Looking for Build Input
#27 |
#28 | |
Can't wait to retire!!
How soon before you get underway?
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#29 |
The LuvShack Garage
I vote for laying back the 71/72 hood
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#30 |
Gotta finish up the K5 tub we're working on, then move onto my 70 swb 4x4 fleet and get it finished up enough to be sale-able and that's how I'll fund the blazer build.
So best case is late spring or summer. Shouldn't be all to bad, the tub is already rust free and I have 90% of all the parts, just need to assemble after I get the firewall welded onto the tub section... ![]() Craig, yeah I agree. I've read that thread and it's a very cool mod, it's on the list. Chevyman63, Jim and I are talking about a blazer/jimmy road trip, you want in? Maybe we'll make you the destination. ![]() |
#32 | |
#33 | |
USMC
Semper Fi |
#34 |
I agree, where's that thread!
![]() Dang, I just thru out my extra hood, figures. So do I understand this correctly, you can turn your '72 hood into a '67?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#35 | |
The LuvShack Garage
#36 | |
#37 |
The LuvShack Garage
#38 |
Why not go with a GEN III motor instead of the TBI? You are already going to have to install a computer if you go the TBI route and why not use a late model motor, they make so much more power and get better gas mileage? Just wondering, it is your build and either will work just fine. I want to put a 6.0 in my 86 K10 and mate it up to the sm465. Sounds like it will be a sweet ride.
#39 | |
![]() Floor/storage space is full and getting a motor/tranny/t-case outta there clears up alot of room. Course if you have a good lead on one... ![]() |
#40 |
Oh..never mind....
I assume that is why you are using the 241 transfer case instead of going with a 205. I thought that the 241 had the front drive line drop on the wrong side. Also, you need to change your drive shafts to the slip yoke style, unless you get one of the eliminator kits. I know that you know all this, but you asked for our input and just was wondering. I am facing facing some of the same issues on my 5.7 Vortec/4L60-E swap and decided to just use the Advanced Adapters output shaft so I could mate it directly to my 205 and not deal with the other drive terrain issues that way.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
#41 | |
Good idea about using a 205 to be able to use the same drive line yolks but you'll still need to mod the length, being the tranny is longer, correct? One other reason for using the 241 is the better reduction. it's got a 2.72 vs. the 1.96 of a 205. With the 700/241 combo I get a crawl ratio of 76:1 (without a doubler) and high way rpm's @ 65mph of only 1936rpm. (w/4:56 gears and 36" rubber) |
#42 |
People know me
be sure you get a sye for that 241, i first installed my 465/208 with an 8" lift and had a 28" long driveline that binded just sitting there, had to find a 465/205 set-up just to get it moving!
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
#43 |
I Think The Solid Side Glass Is Real Neat Ditch Those Wind Leakin Vent Windows You Gotta Want It Though But Thats Cool
Ive Also Wanted To Do Ifs Front Suspension Out Of A Mid 90's Truck Or Tahoe In The Front That Would Make E Sweet Driver Maybe Not The Most Sturdy Off Roader But A Sweet Driver And You Could Get 4:10 Gears In A Half Ton If You Look In The Glove Box Gu3=3:42/gt4=3:73/gt5=4:10 G80=locking Rear Diff But That Again Would Be A Lot Of Work But A Sweet Driver |
#44 | |
Oh..never mind....
I actually am going to leave my 205 in the same place and move the engine forward to compensate for the extra length of the tranny. I have an electric fan from a Lincoln Mark VII , so there should be no interference with the radiator. That is my plan anyway. Otherwise, it sounds like we will have a similar set up. I am running 4:56's and 35's. Right now with the Turbo 350, the big block gets winding pretty hard. With the small block and OD tranny, things should be much nicer to drive and be much more fuel friendly.
#45 | |
Your going to like the new set up, is there a current build thread you could link? When are you doing the swap? I'm guessing the 241 design's overlapped for a couple years. Mine came out of a 1990 solid front axle blazer. Really looking forward to the drivability of mine too. Low 1st gear and happy highway cruising. ![]() |
#46 | |
Oh..never mind....
I have not started a build thread at this point, since I still am in the parts gathering and research stage. I was planning to start the build in the next couple of months, but we plan on moving in the late spring and I do not want to have the Blazer in pieces for the move. Also, I will need to work on my current house and the one we are moving into, so the Blazer is most likely getting pushed back until next year. The plus side is the new place has a heated garage and large storage shed that I can convert into a shop to do the build in. It will be worth the wait to be able to work inside during to wet winters here in the Pacific Northwest. ![]()
#47 |
Here's the latest update/decisions:
*Parts I have/will be using: '69 tub and frame TBI'd 700r/241 Dana 60/14BFF w/4:56 gears and rear locker. 37" MTR's on H2 wheels Double walled hard top *Stuff I'm 99% sure about but still need to gather up: PRP seats, both front & rear Spray in sound deadening 6" front Alcans and 2" rears with a shackle flip and zero rates Cowl induction hood *Considering: A Vintage air set up Stereo of some sort Paint color/interior trim Then there's the cage I wanna build... It's a slow process for me, dunno why. ![]() |
#48 | |
#49 |
#50 |
Oops...I guess I posted that on the wrong thread.
![]() But it does sound like a great combo.
