Old 07-12-2009, 12:16 AM   #26
41GMC
Re: Short water pump VS long water pump?
I have a 72 truck and due to material on hand have installed a 350 engine with a long water pump. Now I cannot find a lower radiatior hose to fit it. I cannot go back and istall a short pump due to using an aluminum procomp timing cover that is so thick that the short pump will not seat.
Can anyone help me with a manufacturer and part number for a hose that works?
41GMC is offline   Reply With Quote
Old 07-12-2009, 11:25 AM   #27
71stroker
71stroker's Avatar
41GMC- is the hose to long to fit or is the angle on the waterpump outlet wrong? I would try trimming a stock one to fit if possible.
My 72 truck has a short pump on it and the motor in it came from a 78 chevy c-10 with a long pump. My issue is that you cant get to the timing mark with a timing light. With the long pump on it you checked the timing between the pump and the timing chain cover. Now the short pump sits against the cover and I have no way to check the timing. I just set it by ear now. Anyone else have this issue?
1971 K10 1/2 ton short fleetside, 4 in. lift, sm465/np205, 383 waiting to go in.
1972 K10 short fleetside converted to 3/4 ton, 12 in. lift, t.350/np205, sbc 350.
1970 C10 short fleetside, saginaw 3 spd, no motor.
1971 GMC 3/4 ton 2wd suburban parts truck.(gutted)
1970 GMC 1/2 ton 4wd suburban t.350/np205 no motor parts truck.
71stroker is offline   Reply With Quote
Old 07-12-2009, 12:34 PM   #28
41GMC
The stock hose for a short pump is all wrong in angle due to difference in pump inlet location.
Old 07-12-2009, 12:35 PM   #29
41GMC
Actually the short pump is wrong in both bend angles and lengths.
