Old 10-25-2007, 04:46 PM   #26
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: front spring removal...Dangerous??
If any body wants to look, I have more details in my diary.
About halfway down this page is where I took them out.
On this page we put them back in.
All in all itīs scary if you never did it before but after you do the first one you see how easy it is.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 10-25-2007, 05:51 PM   #27
cdowns
cdowns's Avatar
when changing the front springs its an excellent time to install new balljoints and tyrod ends as well as sway bar bushings/// i just use a jack and jackstands no compressers chains or other sissey type stuff
Old 10-25-2007, 06:46 PM   #28
blukangoo
blukangoo's Avatar
If you have the weight of the engine on the front you donīt need the sissy crap.
I didnīt have the engine or tranny in and thatīs why I needed the sissy stuff.
My C10 Diary
Our cars:
Last edited by blukangoo; 10-25-2007 at 06:48 PM. Reason: Canīt believe he called me a sissy.
Old 10-26-2007, 06:44 AM   #29
space
Originally Posted by Luvlegs View Post
Space Cowboy - for a 102 year old, it's pretty cool you are still wrenching. Feb 1st, 1905 right? hahahahaha
My birthday is actually Feb 29, 1905, but at my age my vision is so bad I couldn't see that date on the registration form.
space is offline   Reply With Quote
Old 10-28-2007, 03:37 PM   #30
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Finished project! Thanks for all the advice. The u-bolt removal was the easiest. Here's the job and the results. I know it's a double post, but I'm proud I still got all my fingers!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 10-28-2007, 03:40 PM   #31
retodd7711
retodd7711's Avatar
here's my other low-rider!
She's runnin' a 6 inch drop on all fours.
She can't cook
So forget her.
My old farm truck
Old 10-28-2007, 03:52 PM   #32
blukangoo
blukangoo's Avatar
Damn, 102 years old and I forgot your birthday. Happy belated birthday. I definitely wonīt forget your 103rd.
My C10 Diary
Our cars:
Old 10-28-2007, 04:05 PM   #33
blukangoo
blukangoo's Avatar
.....and how far did the springs fly? I hope they just fell out of place just like mine.
There are some people here that donīt want to believe how easy it is to remove and put the springs back in but believe me, when you did it once you wonīt be scared the next time.
I havenīt seen any information here yet that will get somebody hurt.
My C10 Diary
Our cars:
Old 10-28-2007, 04:17 PM   #34
retodd7711
retodd7711's Avatar
The springs never moved just loosened and fell out. The trick is to have truck up high enough to let the jack ALL the way down. You could get in trouble if the jack goes down and the springs are still under compression.But now that I know how, I'd do another truck without fear. Thanks,guys! Here's a pic of old vs. new.
She can't cook
So forget her.
My old farm truck
Old 10-30-2007, 10:16 AM   #35
Wrenchbender Ret
The truck springs don,t expand much & are easy to remove. If you do this on a car you need to use a spring comp. They just keep growing.
Wrenchbender Ret is offline   Reply With Quote
Old 10-30-2007, 06:49 PM   #36
airdale94
airdale94's Avatar
Originally Posted by blukangoo View Post
I think Iīm a little late but I thought I would post it any ways.
The first 2 pics are how I got them out.
Put the jack under the a-arm and remove the u-bolts. Lower the Jack and the spring falls out without flying through the shop.
Putting them back in isnīt as easy but you have to do it in a certain order.
Put the a-arm back in and reinstall the u-bolts. Connect the bottom balljoint and tighten it.
Put packing straps around the jack and frame like in the last picture and raise the jack til you can tighten the upper ball joint.
The straps keep the truck from raising up.
Make sure the bottom edges of the jack are smooth. You donīt want them to cut the straps when lifting.
Just wanted to say...Thanks! to blukangoo. Man that is an excellent idea with the straps. I'm use to doing this on 2nd Gen Firebirds. I always use a spring compressor and try to pull spring out the front. Man what a PITA.
I have a front cross section cut out of an 84 3/4 ton that I've been waiting to tear down (was waiting on spring compressor I ordered), when I saw your idea I knew that was the way to do it. Diddn't even use my new spring compressor.
airdale94 is offline   Reply With Quote
Old 10-30-2007, 06:53 PM   #37
airdale94
airdale94's Avatar
Ah, I noticed that. Also remember my Firebird's "growing". Had to take several shots at it.
