Old 04-09-2008, 02:52 AM   #26
tdkosta
tdkosta's Avatar
Re: finished... Repairing cracked fiberglass top
Originally Posted by fun in dirt View Post
Also put lexan in place of the glass hatch window. This made it sooo much lighter & easier to work with than getting a piece of glass cut & that rubber moulding is a headache.
Nice repare job. How is the lexan holding up? I have some replacement glass ready for my hatch when I get it repared, but might look at going with the lexan if it is lighter and resistant to scratches, discoloration and such.
tdkosta is offline   Reply With Quote
Old 04-09-2008, 07:05 PM   #27
fun in dirt
fun in dirt's Avatar
Holding up great so far! It is alot lighter, probably weighs about 5 to 10 lbs. Lexan will scratch easily though. To clean it I run the water hose on it and wipe with a really soft rag...never use paper towels. Dry it by just kind of dobbing it dry instead of wiping. Then a coat of plastic/lexan wax cleaner every now & then seems to keep it from discoloring. This is what we did with all our drag car & it worked!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 04-10-2008, 02:53 PM   #28
BigRed Beast
BigRed Beast's Avatar
Re: Repairing cracked fiberglass top
Looks like you did pretty good with the top...I'd love to see you post some up close photos. Not that we're checking your work or anything
Big Red Beast
1972 Blazer CST AC/Auto/4x4 "Project"
1997 F 350 CC Powerstroke "The Great White"
BigRed Beast is offline   Reply With Quote
Old 03-17-2010, 05:58 PM   #29
truckeez
One tip-The regular auto parts store bondo brand resin is JUNK, go to lowes and get their epoxy resin kit in the paint dept- polyester resin doesn't want to stick good to anything. epoxy will bond much better.
truckeez is offline   Reply With Quote
Old 03-18-2010, 08:26 AM   #30
BigRed Beast
Way after this thread started, I came across www.fiberglassforums.com. I know I've mentioned the site in other posts, but I'll say again: a tremendous amount of information about glassing. I thought I knew something about the subject, then I started reading what some of these guys do and it's just incredible.
Guess it would have been helpful to have several years ago, but maybe it'll inspire some newer repairs...
Big Red Beast
Old 08-14-2012, 10:29 PM   #31
gmclonghorn
gmclonghorn's Avatar
Anybody know who does nice restorations of tops in southern california thanks
gmclonghorn is offline   Reply With Quote
Old 08-15-2012, 03:13 AM   #32
Truckman73
Truckman73's Avatar
Longhorn, I talked to a boat repair guy here in Temecula that does some pretty good work on fiberglass/smc. If you do a google search for "Doc Dings" he should pop up. The down side was he is pricey...I bought a can of epoxy and just started my own top this week...
Truckman73 is offline   Reply With Quote
Old 08-24-2012, 03:15 PM   #33
SamMargritz00
SamMargritz00's Avatar
don't you need to be using SMC resin?
SamMargritz00 is offline   Reply With Quote
Old 08-24-2012, 10:02 PM   #34
Truckman73
Truckman73's Avatar
Yes...do the research and get the resin/epoxy that is compatible with the SMC, I bought the Evercoat brand. If you use the incorrect stuff it has a tendancy to expand and contract at different rates than the rest of the top. Also be sure to prep the areas properly, the boat repair guy told me that was a key, as well as ratio of hardner and resin.
