Old 01-01-2008, 07:50 AM   #26
54 jimmy
54 jimmy's Avatar
Question Re: ok lets see them
ok gr8one whats up. no pic no news. hows the frame swap going. been waiting for some updates?
54 jimmy is offline   Reply With Quote
Old 01-01-2008, 05:14 PM   #27
monzadood
here is mine.
1951 chevy truck
1983 gmc crew cab dually
1988 4wd suburban
monzadood is offline   Reply With Quote
Old 01-01-2008, 05:17 PM   #28
monzadood
here is one from this summer.
1951 chevy truck
1988 4wd suburban
Old 01-01-2008, 06:34 PM   #29
Lrall
Lrall's Avatar
whered you get the rims^^ theyre SICK
Lrall is offline   Reply With Quote
Old 01-01-2008, 06:59 PM   #30
Daniel U
Daniel U's Avatar
What he said, and cool truck!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 01-01-2008, 08:44 PM   #31
monzadood
those are hubcaps from a 1950 olds with bullets.
1951 chevy truck
1988 4wd suburban
Old 01-02-2008, 02:45 PM   #32
gr8one
ok 54 jimmy im glad to see that people are interested in this build, im putting the truck completely together then im going to take it back apart and make a step by step guide. ive been working alot of hours at work. to start with i set the cap 2" above the s-10 frame with 2" tubing, i did ron into a probelm with mounting the bed. i welded 1 1/2" tubing (instead of the 2" factor bed supports). here are some pics. let know what you all thank about this build. oh by the way this truck has the mid-size bed and an EXTENDED cab is 1" short on the wheelbase but i made that up with distance between the cab and the bed.
gr8one is offline   Reply With Quote
Old 01-02-2008, 02:52 PM   #33
gr8one
Smile Re: ok lets see them
im going to lower the rear fenders to match upto the running boards. the cab fit really good but like i said the bed was trick. here is a before pic of the s-10 i also have 3 other builds going on. i the last pic if look you can see the red 2" tubing that the body mounts to the frame.
Old 01-02-2008, 03:02 PM   #34
gr8one
almost forgot about the rearend. I removed the s-10 rearend and bought a mid 70's camaro rearend for $100.00 at local junk yard. ok here is the part your not going to beleave i used the s-10 backing plates and brakes on the camaro rearend. the factory brakes from the s-10 bolted up with no modifcation, just bolted right up.
Old 01-05-2008, 04:05 AM   #35
54 jimmy
54 jimmy's Avatar
comming along great. I ordered the ad for my truck. are you going to do any paint and body work on your truck? I'm not going t paint mine,going for the rat rod look.
Old 01-06-2008, 11:00 AM   #36
solidaxel
solidaxel's Avatar
gr8one,
When you lift the cab and dog house, how much stress is on the front fenders at the cowl, does it not bend with all that weight, how do you have the fenders supported?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-06-2008, 11:50 AM   #37
gr8one
solidaxel,
i bolted the fender without the inter fenders no damage to any of it, you are lift the cab there is nothing on the doghouse. i used the doghouse to line up the front tires.
Old 07-09-2008, 12:53 PM   #38
63 & 64 Bowties
and a few others
any updates?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
