11-20-2007, 12:52 PM | #26 |
Re: Why is there a clutch pedal in my truck?
Lets look abit closer! Alright is there a metal stick or shaft with a knob on it coming out of the floor near the center or closer to the steering wheel? Does the car take off by itself when you start it? If you have said yes to these queations the truck is a stick or manuel transmission truck!
11-20-2007, 01:04 PM | #27 |
Ok, so was this peddle pushed to the floor (under floor mat) or was it a very obvious (can't believe you didn't notice it before while sitting in the drivers seat, could of pushed it in at anytime while driving) peddle hanging there, or is it a clutch peddle cut off at some point between the peddle pad and the pivot point? I'm not following the visual here.
Feel feel to PM me your response... I'm using a clutch pedal assy in my auto truck I'm building, so my plan it to either find a space from an Auto truck or cut off the clutch pedal arm up close to the pivot point.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 11-20-2007 at 01:05 PM. |
11-20-2007, 01:04 PM | #28 |
LOL! Dude, you should have known better than to expect a serious answer to a question like that. IF you're not dreaming, and you have taken that second look to make sure it wasn't a gremlin's leg hanging outta the dash, then I'm with a previous poster who suggested that BEER may have somehow been responsible for the extra parts.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 11-20-2007 at 01:05 PM. |
11-20-2007, 01:29 PM | #29 | |
Fat Fendered Fleetside
But I put a B&M shifter with a manual shift boot to cover it up. I laugh my ass off when people think the broke the clutch and can't get the shifter in 'first' This thread rocks |M|
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
11-20-2007, 01:56 PM | #30 |
chrome makes it go FASTER!
How do we know this is actually a clutch pedal? If it's in an automatic truck then it's just a pedal, not a clutch pedal.
Could be a very RARE option.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 Last edited by retodd7711; 11-20-2007 at 01:57 PM. Reason: . |
11-20-2007, 02:06 PM | #31 |
Who's got steelies?
When I switched cabs the new cab had a clutch pedal in it. I thought of leaving it there, but it was easy enough to remove, just remove the bolt on one side and the pedal and shaft slides out the other! Maybe you should leave it there as a joke!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-20-2007, 02:25 PM | #32 |
Anything can happen over the years. I had a 70 monte carlo a long time ago & I was going to install a 4 speed in but only got as far as installing the pedals while I hunted the other parts needed. Along came a fella that wanted it worse than I did. Sold it to him & now your story reminded me of that car. Maybe someone was going to install a manual trans or did install a manual trans for a while & you ended up with it. I wouldnt worry about it & if it gets to you, just take the pedal out & install a spacer...
11-20-2007, 02:47 PM | #33 |
blood type; Retumbo
this reminds me of when I swapped in a TH350 into mine. I never got around to crawling under the dash to remove the thing at all. I covered the hole in the floor and swapped in an auto column from a later truck. then a few months later i took it in to get new exhaust run. the guy called me later asking "how the *&^% do I start the thing and where is reverse?" he got confused by the column mounted lock cylinder and the clutch pedal. LOL
11-21-2007, 12:57 AM | #34 |
huh ???
I had a Bronco that was reversed. Originally an auto and somebody swapped in a 4 spd leaving the auto column. I freaked a buddy out one night, driving in 4th gear, yanked the column shifter into low and floored it. Told him I needed more passing gear. LOL Should of seen the look on his face...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-21-2007, 01:53 AM | #35 |
11-21-2007, 05:58 AM | #36 | |
I helped my neighbor put a Saginaw 4spd in his`68 a couple weeks ago.I see he`s been driving it around.Now this guy parts trucks out all the time.He tears them down all the way.I stopped by yesterday,but he wasn`t there.I looked in his`68 to see how the shifter worked out.He still has the 3spd shifter in the column.I`m sure he knows how to pop the pin out by now.
11-21-2007, 12:36 PM | #37 | |
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
11-21-2007, 01:29 PM | #38 |
This reminds me of when my buddy in the Navy didn't notice the "girl" he was dancing with in Rio, Brazil needed a shave...
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
11-21-2007, 01:34 PM | #39 |
That reminds me of a story from when I was in Japan...but this is a family site.
72 C10 lwb fleetside -stock 350/350 combo |
11-21-2007, 02:45 PM | #40 |
PROJECT 7DEUCE
Any progress of where the pedal is?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
