Old 12-28-2007, 08:09 AM   #26
2wpuller
Re: 72 C10 with Cummins
I got 365hp,854lb torq out of his 93 cummins with POD injectors,hX35 turbo14cm Ex,housing,4"exhaust.and some pump work that I did on the truck.He still gets 21 to 23 depends if he is playing with the go pedle.
Dale
2wpuller is offline   Reply With Quote
Old 01-08-2008, 04:51 PM   #27
70rs/ss
70rs/ss's Avatar
How did you mount the motor to the chev frame? Is there a kit to mount thew motor in there? I am in the process of getting a 69 motorhome (Chevy, of course) So I am pretty sure the Cummins will go in there. It is made in 92 but is a 93 or made in 93 and is a 94, can't remember, how do I make it work?! I have your number, but it seems like there are a few of us here wanting to do this so maybe if you can tell us here we won't be bugging you with the same questions over and over?
70rs/ss is offline   Reply With Quote
Old 01-15-2008, 05:46 AM   #28
2wpuller
Sorry it took me solong to get back on here I have been very busy with my other prodject truck75 f.... ,the trany went out on the 72 this week yesterday We started to change over to a NV4500 light duty out of a chevy and going to change out the rear end to a 86 with 3.8 gears the old rear had 4.10 going for 25 too 30 mpg. will take pic of the motor mount for you. Dale
Old 02-08-2008, 12:27 AM   #29
Dick Furious
Definitley inspired! I too would love to see some pics of the mounts as well. I was thinking about swapping a Duramax into my '71, but it's pretty much cost prohibitive. Any advice for someone else looking to do the same thing?
Dick Furious is offline   Reply With Quote
Old 02-08-2008, 01:09 AM   #30
jwcardy
yeah this seams like a very interesting swap...
-wes
jwcardy is offline   Reply With Quote
Old 02-08-2008, 11:31 AM   #31
D-Monkey
what kind of electrical work goes into a swap like this?
D-Monkey is offline   Reply With Quote
Old 02-08-2008, 12:40 PM   #32
skchevota
skchevota's Avatar
Originally Posted by 68K20 x Drill View Post
All the Cummins Engines are direct injected diesel fuel into the combustion chamber.
Up to 1988 1/2, the fuel system is mechanically controlled, needing only power to the injection pump to run. Newer trucks use a computer. In factory form most need a tach signal, or they shut down.
Dodges come with a weaker Getrag 5 speed, stronger NV4500, or even stronger NV5600
or a 4 speed auto that has the same issues as all work truck autos.
Grumman GM step vans have a 4 cyl version of the same motor, and use a TH400 or SM465.
96-98 3/4 ton Diesel Dodges with a stick shift can get 25+ MPG, and put out
in stock trim, and 300HP/600FtLB is not extreme, so towing is not a problem but you may lunch a stock tranny after awhile.
The cummin's engine was actuly sill a mechanical injection system 89-93,the early cumputers controlled converter lockup, and the intake heater. The engine will still run with just one wire. In 94 Cummins chanjed injection pumps to a p7100, this pump has the ability to produce some serious HP, the injectors are also different and the computer plays a few more rolles with the trans, and emition systems. In 1998 1/2 Cummins went fully electronic, and to 24 valves. With the later engines you install fuel and timing boxes to the computer to rais power levels. I run a 93 that has a stock turbo, 4" exhaust and the pump is turned up. it has way more torque than the big block 402 had and gets 18-20mpg with 37" tires.
skchevota is offline   Reply With Quote
Old 02-22-2008, 11:22 PM   #33
2wpuller
You can still get some high hp. out of a 93 5.9 cheap.Sorry I haven,t got the pic of the mounts yet the are very easy to fab up real simple.the truck is alot more fun to drive with the stick in it.The N50x15 don,t stop squaling til you get into 5th.I dont have her turned up that much YET My wife don,t know that I have some SLIGHTLY larger injectors and a 3600 rpm gov, spring for for her Grocery Getter all my buddies call the truck GG. Next thing I need to do is replace the insterment panal with new one from Dakota Digitalso I can get the electrical speedo to work and tac.I put some of the sound deadner called Dynamat work real well the man at the sterio shop sead I over killed puting it in i covered every spot made one heck of a differance.you can hear some one talk to you now while your driving.
When it gets warmer I have the 3.08 reaend to put in.It is sleeting and snowing to day .
Dale
Old 02-22-2008, 11:29 PM   #34
2wpuller
The bucket seats that are in the truck now are to thick dont have any leg rome I,m 6ft my wife is 5.10 I didnt like the stock bench will the stock bucket seats give you mor leg room than the bench.I going to look at some Kerkey seats .Waht do you all thing what would work the best.
Dale
Old 06-17-2008, 12:34 PM   #35
2wpuller
The rear end fiially went out replaceing it with 3.08 out of a lat 80s.Had schoulder surgery on april 7 still not back to work just pedling around.
Dale
Old 06-17-2008, 09:29 PM   #36
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Can you maybe take pics of everything? The whole truck inside and out, engine bay, underneath? I would love to see more on this swap. Good job!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-18-2008, 09:50 AM   #37
2wpuller
I will take some pic, today while I,m changing the rearend.
Dale
Old 06-18-2008, 12:34 PM   #38
thirdstreettito
Resident of Here
Thanks!
~Bradley~
Miss having a truck
Old 06-18-2008, 01:59 PM   #39
Big J
Its lookin' like a Blazer!
Big J's Avatar
Can't wait for pics! Been wantin' to see more of this one for awhile!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 06-25-2008, 07:57 PM   #40
thirdstreettito
Resident of Here
We took the turboed charged smallblock out and the 5 sp
More info please!
~Bradley~
Miss having a truck
Old 06-25-2008, 07:58 PM   #41
thirdstreettito
Resident of Here
Oh yeah, we are still waiting for more pics...a week later...
~Bradley~
Miss having a truck
Old 06-26-2008, 10:06 AM   #42
2wpuller
Sorry about the delay I have been doing repairs on the pulling truck.I promiss I will take them today.
Dale
Old 07-18-2008, 11:03 PM   #43
kamikazekyle05
kamikazekyle05's Avatar
Any updates? That thing is awesome!
kamikazekyle05 is offline   Reply With Quote
Old 07-18-2008, 11:05 PM   #44
lo04chevy
wow
lo04chevy is offline   Reply With Quote
Old 07-19-2008, 02:15 AM   #45
milled
milled's Avatar
wow, looks like a high mount turbo. nice pickup!
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 09-21-2008, 12:43 AM   #46
thirdstreettito
Resident of Here
Any updates?
~Bradley~
Miss having a truck
