12-06-2007, 02:56 PM | #26 | |
Re: Carb Questions
I'm not sure what you mean by vacuum on the carb, but the distributor advance will be connected to either the carb or manifold - whichever it is connected to should be disconnected at the distributor and plugged at that end...otherwise we end up with a vacuum leak. |
12-06-2007, 05:42 PM | #27 |
Re: Carb Questions
Thanks for the info. I've read the manual, but must have missed that portion.
As for the vacuum on the carb, I was refering to the diaphragm on the passenger side that opens the butterfly on the front side of the carb. Again, greatly appreciate your help. |
12-06-2007, 09:15 PM | #28 |
Re: Carb Questions
12-07-2007, 12:18 AM | #29 |
yes, i do
Re: Carb Questions
the diaphramed vacuum port on any carb is generally refered to as a gated port. i usually find it better to hook the tranny to that port and the carb to the fully open port.
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
12-07-2007, 10:46 AM | #30 | |
Re: Carb Questions
Carb vacuum secondaries are internally connected to ported vacuum on all the carbs I'm familiar with, so usually there's no opportunity to connect them differently...and you wouldn't want to. If your experience is different, a picture of what you're describing would be helpful. Ported vacuum is vacuum taken from above the throttle butterflies, and so has little or no vacuum at idle. Non-ported vacuum is taken from the manifold directly - either from a fitting on the manifold or from a carb fitting that is below the throttle butterflies. Generally, transmission vacuum modulators should be connected directly to manifold vacuum, usually to a the fitting behind the carb on the intake manifold where power brakes (if present) are connected as well. For distributor vacuum advance, there is active debate about where it should be connected, but a good rule of thumb is that stock or near-stock cammed engines should use ported vacuum, but a more performance-oriented cam should use manifold vacuum as the additional vacuum - and so, additional vacuum advance - at idle can smooth out a bumpy idle with the bigger cams. Note that this only affects idle and near-idle; once the butterflies start to open the two fittings will show nearly identical vacuum. |
