Old 12-14-2007, 06:05 AM   #26
Roper
Re: To those who have had bodywork done... $ per hour?
About doing it yourself. Whats the deal on replaceing/welding cab corners with those fuel tanks right behind them? That part would make me nervous! Do pros lift the cab before welding on rocker/ cab corner panels? Do they do it outside or am I worried over nothing?
With a diesel tank you can pump exhaust fumes into the tanks so they wont blow up when you weld on them but what do you do with a gas tank?
Roper is offline   Reply With Quote
Old 12-14-2007, 09:39 AM   #27
Russell
Professional Grade
Russell's Avatar
The gas tanks arn't really close enough to cause problems. Just make sure you have a good cap, hose etc so there are no obvious fumes to ignite.
If you are really concerned about it, dropping the tanks is no big deal after you siphon them out
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-14-2007, 04:33 PM   #28
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if youre going to siphon em out leave the caps off for a day or two and there wont be anything in there at all to ignite
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-14-2007, 07:25 PM   #29
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Cab corners and gas tanks are no biggy. Take the advice given in previous posts and make sure there are no vapors present. Fill the tank as the vapors are what do the igniting. I just place a leather welders apron on the inside between the tank and cab corner being worked on. Do as much work yourself ie. strip paint, remove old bondo, clean the frame, zero rust the frame, top coat the frame, strip trim, install trim do the interior etc. this grunt work all adds $$$ to the projects bottom line. This is also fun as you can say when it's all done that you were hands on a part of your truck project.
esll.
Painting the frame is also a good way to get hands on experience using a paint gun.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-15-2007, 04:34 AM   #30
Russell
Professional Grade
Russell's Avatar
Ah, everything from the frame down is already done Both axles are totally overhauled and painted, steering was overhauled, same with the frame rails, engine, transmission transfercase and driveshafts. Even the e-brake and brake lines are all brand new
The work I need done is purely body sheetmetal including the cab, outer fenders, front clip skirt, cab, doors, box and tailgate
Old 12-15-2007, 02:12 PM   #31
Wwildman
I presonally would remove the gas tank or tanks
Wwildman is offline   Reply With Quote
