12-16-2007, 03:30 PM | #26 |
Re: need to see some electric fan installs
these trucks got pretty wide rad's so like totalchevy says il be mounting as far to the driverside as possible but with a mark VIII fan im thinking it will be pretty tight
12-16-2007, 04:02 PM | #27 |
Moving it to one side should keep the fan and the pump centers away from each other. Plus if you have at least 1/2" clearance between the pump and the fan you'll be fine. The motor doesn't move that much, unless you lose a motor mount, then your screwed anyways. Have you trimmed it. I took 3/4" off the schroud which put the high point at just under 5 inches. It gave the fan about 1/4" clearance between it and the rad. They guy I sold it to said it works great, just make sure you secure it...its a strong fan. If you us the pull through deals I would use 6 of them
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 12-16-2007 at 04:07 PM. |
12-16-2007, 04:08 PM | #28 |
Turbo Guy
A taurus fan and a long water pump with a bbc will not fit. I had mine slid back 3/4 of an inch (73 up mounts) and it was still too tight. I don't remember whether it could be slid side to side to clear but it was just too tight for me. I ended up putting it in my friends 67 with a sbc. Taurus fan does pull alot if you use the high speed wire, not too much though. I used a 30 amp breaker (after I blew the 20 amp 4 times) and it was fine.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
12-16-2007, 07:34 PM | #29 |
if worse comes to worse il get a custom shroud made, i know a welder/fabricator pretty good.
hey 71/454 were you mounting your fan in line with the water pump? where was it hitting, on the motor of the fan? |
12-16-2007, 07:39 PM | #30 |
oh i hate those thru core mounts, il figure out a way other than that
12-17-2007, 04:41 AM | #31 |
I know this is not a BB but here is my simple fan set up. I used two fans to conver the entire radiator. O:ne therm comes off of the motor and the other off of the radiator. I used spal switch on one and the other is the one that came from the fan complany I picked up at my local hot rod store.
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
12-17-2007, 08:59 AM | #32 |
you could almost fit another small block chevy in there between the rad and engine
12-17-2007, 07:13 PM | #33 |
Been a long time since I've contributed anything. I'll do my best to get pic of my set up, and will post tomorrow.
12-18-2007, 04:49 AM | #34 |
I finally got some pics for you. Even with the right side of the radiator open, it cools pretty well. I think I also turned the fan upside-down. It looked better and there's no need to see that Ferd sticker.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-18-2007, 10:36 AM | #35 |
thanks clay thats just what i was looking for. although yours is a short pump im thinkin this could be a real party for me to make it fit with a long pump. the long pump is an inch and a quarter longer from what i read...so il try to work the core support a bit for some extra clearance and trim the shroud as much as i can.
12-19-2007, 11:46 AM | #36 |
well i was buying a new water pump anyways so after seeing those pics i think im buying a shorty. just have to find some brackets now
12-23-2007, 03:35 PM | #37 |
Turbo Guy
Sorry for the late reply, I forgot about this thread. I don't remember exactly how it sat but seeing those pics of a short waterpump reminds me that it definitely was too close.
