10-13-2002, 02:30 AM | #26 |
Thats the Hillbilly way
Just checked the fluids , and took it to get some dinner .
Too much good football to do anything else.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
10-13-2002, 02:39 AM | #27 |
Got front end on the '68 aligned after swap to true dually front end. Routed power bucked seat wiring to switches in custom MTX console. Chopped frame out of doner dually and began prepping rear suspension for swap tomorrow. Finished cleaning up braided hose routing for hydroboost brakes. Welded '72 style brake tabs on front of frame crossmember to support braided front brake lines. Prepped the roller heads for the BBC to drop in next weekend. Looked in amazement at the pile of tools on the garage floor... Shut down and drank a beer or five to think about cleaning up tomorrow! It's the never ending story!
Hot Rods in Aggieland! Custom Airbrush Artis Die Hard Old School hot Rodder |
10-13-2002, 04:25 AM | #28 |
Converted my points distributor to electronic using the pertronix set-up. I have a 250 straight six and with the a/c compressor an hei wouldn't fit. The Pertronix set-up made it nice. No more points!!!
Later.
FGC |
10-13-2002, 09:10 AM | #29 |
Captain CAAAVVVMMMAAANNN!
hmm, ut air in the front tire, then stood there and wished I has some money to get some parts for her. I don't know about you guys, but I'm tired of being broke! I wanna buy stuff for my toys!
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
10-13-2002, 09:28 AM | #30 |
She's just sittin in the garage waiting for me to be able to afford an engine swap.
10-13-2002, 09:47 AM | #31 |
Fabricate till you "puke"
I pulled the fan & rad shroud ( for faster warmups if I need to move her this winter). it looked so much "cleaner" without those pcs that I fabbed a steel shroud to run dual electric fans. I have a list of stuff about a mile long to do to her this winter, but probably wont get back to it for a while. Just set my "spare" 355 in the plow truck, & have general maintanence to do to that.....also have the eng down on the sand rail for an overhual, & outside stuff to do on the house........too many things to work on!
10-13-2002, 11:02 AM | #32 |
truck procedure
uh, drove to my mother in laws and parked it . im tired now
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it |
10-13-2002, 04:59 PM | #33 |
Nothing, Absolutely Nothing
Build Thread |
10-13-2002, 05:48 PM | #34 |
umm moved whats left to put on of the front clip to the otherside of the bed so that way at least while it sits in the yard long enough to sink it sinks evenly. found some spare parts I didnt know was in there and ummmm something else. not sure exactly what it was. possibly from the leaves falling the first fall it was out of the factory. looks old enough to be anyway. the main stuff is waiting til winter when I cant work outside. thank god for the shop.
10-13-2002, 06:46 PM | #35 |
heater....springs.....shocks
and even in that order...worked on the heater assembly 1st per my previous post about having little to no heat...heater core was in upside down...housing was surprisingly clean...but after remounting heater core, i have all the heat that i will ever want...
then moved on to the rear coil springs..with a little encouragement from the smoking wrench those came off and the new springs went in as well as the shocks...all in all a pretty eventful day under the ole 69......
94 K1500 SWB w/ 4" body and suspension lift |
10-13-2002, 06:48 PM | #36 |
Glad to see you got your heater problem fixed... Now you'll be wishing that thing would shut off when you dont need it LOL. Put a shut off valve in the hose coming from the intake to cure that problem (in summer time that is).
10-13-2002, 07:14 PM | #37 |
Drove it to town and bought a replacement end for the broken antenna cable. Installed it (yuk)
Put the glove box back in (double yuk) and installed the glove compartment door. Hiked up the heater box and put in some self-tapping screws to hold it in place. Dusted it off, had a beer while I sat and looked at it. |
10-13-2002, 09:30 PM | #38 |
long day
just got back from a short drive(862 miles round trip) left at 2am to Ga. to pick up a cab for my project K20 boy that cab fit perfect in the bed of my pu. got to meet fellow board members who had a backhoe which made loading a snap after we removed the steering column and heater thanks for the help guys .well now I can look foward to start dismantling every thing man do I need a bigger shop.
10-14-2002, 12:32 AM | #39 |
Not Dusti,just Bob
Replced drivers side door,the one that was on the truck had been replaced by a P.O. and needed to much work so I got one that only needed the mirror holes filled in,used different style mirrors,
72 cheyenne super 1/2ton 89 camaro |
10-14-2002, 12:50 AM | #40 |
My other Love
well i threw a new battery in the 77, put a new carb on it, topped up the tranny fluid, put anitfreeze in the radiatior, then started and terroeized the neigbourhood until it ran out of gas
With my Ford i hauled 2 loads of gravel for the floor of the wood shed that i have been building, then i put more gas in the 77 silverado and terrorized the neighbourhood some more
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
10-14-2002, 12:52 AM | #41 |
Slowly getting CRSS...
sadly not a d@mn thing... never enough time!
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
10-14-2002, 03:26 AM | #42 |
Loaded my grill and tools in it and went to a friends house to work on his 70. Took the front clip off, the cab off, and took the bed apart since we need to replace the floor and 1 bedside. Does it count working on someone else's truck?
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
10-14-2002, 08:45 AM | #43 |
Nothing !! But i did tell it Good Night and read a bedtime story!
Chris click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
10-14-2002, 10:34 AM | #44 |
Post Whore
Pulled the 454 from the donor vehicle Friday night and thought about cleaning it up as I did other things this weekend!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-14-2002, 11:23 AM | #45 |
Nothing on mine but got my buddy's running. New carb, plugs, oil&filter, trans fluid, fuelpump, battery. Now it only needs all the body work and paint done, a new interior and some wheels.
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's |
10-14-2002, 03:14 PM | #46 |
Rust Repair
Worked on cab- many parts need to be replaced, So far I have cut the right floor board, rocker and cab corner. Hope I can start welding those next weekend so that I can move on left side after that.
10-14-2002, 03:39 PM | #47 |
Southern but in Ohio!!!!
worked on my bedsides, cut out rust weilded in new metal, grinded & primered. I work on it every day if I get the chance. I got rust coming threw top of windsheild witch SUCKS.... going to cut weather strip & take wind sheild out to see how bad it is.... I got stainless trim off another truck I'm putting on, & I'm still dreaming of having my own shop to restore these trucks..or sell parts, Anybody got any tips on how to get started in a buissness...
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
10-14-2002, 03:49 PM | #48 |
Cantankerous Geezer
Dismantled my heater to figure out why it wouldn't work, followed by cursing the PO for leaving parts out when he assembled it. Ran over and saw Jeff at Bowtie Bits www.bowtiebits.com today at lunchtime to get the parts. Hopefully will have heat before first frost!
Fred There is no such thing as too much cam...just not enough engine. |
10-14-2002, 04:00 PM | #49 |
I plan to change the oil and do a lube job after work this evening . . . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
10-14-2002, 04:03 PM | #50 |
I am Kayser Soze
Drove it to work today. Yesterday I reattached my heater hoses to the heater core. Starting to get cool enough to make me want a defroster in the mornings. Saw someone post about using a shut-off valve. *smacks head with obvious work-around*
Need to put my new choke cable in so it's easier to start in these cooler mornings, too. 68ChevC10
1968 Chevrolet C10 Stepside. My driver. Ain't life cool. |
