#26 |
Old member
Re: Switched Power Source...
If our trucks are setup right you really don't need a electric fan at all inless you pull a lot or sit in a lot of traffic. The more air flow you get through the radiator the better cooling you will have. This is why I installed the cover between the condensor and radiator support to help force more air threw. I can't really say if it does or doesn't help but my electric fan is under there too!
It also forces the air threw my home made cold air box also!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 |
I have always heard that the old coil wire is less than 12V... does it matter if it's only running a relay?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#28 |
Old member
If he is using the wire with a HEI then it's not got the resister in it anymore or his truck wouldn't crank. I did the same thing just cut the old resister wire out of the harness and used it for the HEI. At least mine wouldn't at first.
