Old 01-04-2008, 08:57 PM   #26
smbrouss70
smbrouss70's Avatar
Re: Coil spring rear suspension?
Originally Posted by SCOTI View Post
I believe the measurement is 34".
I just measured my ECE crossmember that I got for Christmas (and is still in the living room ) and it is 33" wide. I know, not a huge difference, but figured I'd point that out.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-05-2008, 05:31 AM   #27
crazy longhorn
Fabricate till you "puke"
The rails do measure 34" out side to outside on the 67-72's......IIRC, the 73 up trucks are just a fraction more(1/8" or so). The crossmember needs to be just a tad shorter, to twist it in crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-05-2008, 06:54 AM   #28
nico
nico's Avatar
Wow... An uncle (who is working on his '67) and I were just talking about doing this swap to my 84 C10...
I have access to several 67-72 crossmembers and rear suspension setups through friends and local salvage yards... How similar are the frame thicknesses? Trimming the length of the crossmember would be no problem, but trimming the height to fit inside the 73-87 rails seems like it could cause strength problems...
Will the early crossmember bolt into the later frame (after drilling new holes)?
nico is offline   Reply With Quote
Old 01-05-2008, 07:32 AM   #29
crazy longhorn
I spliced a 78(rear half of the frame had rot issues), in the area we are talking, a pc of 6" channel iron slid in snug to reinforce the area. I cant say for sure on the height on the 67-72 frame, as my longhorn is different(1 ton frame). Im sure someone will chime in tho..... crazyL
Old 01-06-2008, 08:08 PM   #30
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Tony@AirRideTech View Post
When we started developement of a new rear kit for the 73-87's we originally looked at doing a trailing arm set up like our 63-72 rear kit. .....
Thanks for dropping in on this Tony. I moved it here from the 73-87 forum in hopes of getting some expert input.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-07-2008, 02:33 PM   #31
87Wrangler454
87Wrangler454's Avatar
Frame rails on my 87 are as stated above 34", I believe the channel is 6" on 1/2 ton and 8" on my 1 ton, have to check for sure.
87Wrangler454 is offline   Reply With Quote
Old 01-11-2008, 03:14 AM   #32
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The 63-72 style trailing arm style suspension will work great. Although, it should be combined with a Watts link instead of a track bar.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-11-2008, 09:06 AM   #33
Scott68-93-97
Scott68-93-97's Avatar
Build your own look at my 97 build, I used the stock leaf spring mount gusseted and a bushing end on a 2x2 1/4" wall tubing with a leaf spring center pin in it and bolted it to the axle just like your leaf sping (after a flip kit) you can run a panhard or a watts link but I made an upper wishbone link that has a driveline slip built in so it keeps my axle centered and doesn't bind up with the solid trailing arms total cost was $40 thats building it yourself very easy a square and home made jig is the best way to set the bushings on the bars correctly and the setup works great and since I have a two peice driveline so the bars are almost as long as the rear section of driveline so my pinion angle stays good throughout the whole range of motion, the upper wishbone cost me $45 cause I had to buy 2 bushings and a superflex joint, I'll get some pics of the wishbone on the 97 build soon
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 01-13-2008, 10:37 AM   #34
Tony@AirRideTech
Junior Member
N2 ...... no problem man..... one of the other problems we ran into was not the width of the frame but the rise or the kick in the frame.... the trailing arms want to hit the frame rails before the truck gets down.....
Tony@AirRideTech is offline   Reply With Quote
