Old 01-10-2008, 02:24 PM   #26
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: Eaton vs. 14 Bolt vs. Dana 60
Pretty much just a bolt on.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 01-10-2008, 09:48 PM   #27
earl87gta
earl87gta's Avatar
they just bolt on i took aset from my 14blt and used them on my eaton.
you eaton probly allready has 4:56 gear you can use a locker from a 14blt and save some money. I think I have a 3rd on the shelf here already set up Ill look for you.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 01-11-2008, 03:38 AM   #28
FormerMember
Originally Posted by Ridin' High View Post
ok so i found a shop in utah that rebuilds 14 Bolts. He will build me one with a detroit locker and 4.56 gears for about $850. I think thats what I am going to do.
Thank you for all your input!!
That's expensive.
Hell, find a 14B out of a CUCV if that's what you want to do. Should be less than 500. Last one I bought was 250.00 and it had less than 20K miles on it. Most have Detroits and 4.56's.
FormerMember is offline   Reply With Quote
Old 01-11-2008, 03:53 AM   #29
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
I did not know any of this...this is interesting....so let me get thie straight....if the R & P 3rd member in my Eaton dies, a GM 14 bolt will "bolt" right in? That seems almost too "simple" a fix.
Does anyone have any before (all eaton) & after (14 bolt installed) pics?
Thanks!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 01-11-2008, 04:15 AM   #30
FormerMember
Thanks!
Frank
Yes, for the most part.
A 1 Ton 14B has the same spring pad spacing as our 67-72 Chevy trucks. In my C to K conversion, I use a 1Ton Dually 14B in place of the Eaton that was in there. It's a bolt in. Granted, I don't know about the drive shaft length, because I am having one built for this particular and peculiar truck...
Some of the other talk is about taking the side gears and axle shafts from a 14B and added them to an Eaton.
Old 01-11-2008, 06:21 AM   #31
Old Chevy Mech
Keepin it runnin!
I see, that clarifies that
Thats what I'm really curious about, swapping the guts
Frank
1970 K-5 4X4 Blazer
Old 01-11-2008, 03:52 PM   #32
kris's66lwb
resident wrencher
yea could i take the guts out of a 14b abd just bolt it in i think mine has 513s it it its fin low i got the motor at about 5k to get to 55 i know its a lil of topic what disks could i use for my d44 front
kris's66lwb is offline   Reply With Quote
Old 01-13-2008, 10:02 PM   #33
earl87gta
earl87gta's Avatar
I think only the locker and axles will work you still have to use gears and a carrier from the eaton. I think I have a frew threads saved some were on this Ill try to find them.
Is your d44 drum break? If so cheapest thing to do is replace the hole front end out of a newer truck.
Earl
Old 01-16-2008, 10:07 AM   #34
~Shep~
~Shep~'s Avatar
I am interested in this as well. I'm gonna need to do some work on mine soon, but I was convinced I would have to swap in a 14B. I'm about to do a search on Eatons, but I am assuming ya'll are talking about a BIG 10 bolt rear end that comes apart in the front like a 9inch ford...wich is what I have.
1972 Cheyenne K20
Cool Options Include Manual Throttle - Tilt - Dual Gas Tanks - Sliding Rear Glass
...they just forgot to put a super emblem on at the factory!
~Shep~ is offline   Reply With Quote
Old 01-24-2008, 12:43 AM   #35
shelby987
shelby987's Avatar
The eaton is "a big 10 bolt with a 'ford like' center section" I was unaware that you could swap any parts from the 14b into the eaton.....I would imagine it would be somewhat limited to carriers and shortened shafts.
That being said, and getting back to the original question, I would say hunt around for a no-spin eaton third with 4.56 gears already on it. I bought mine (4.10 gears) for $200, it is a relatively simple swap....
-Pull the axles out
-remove the drive shaft
-Drain Diff.
-Unbolt third member (this is definately the hardest part....getting the 120lb sucker in and out while laying on your back under the truck)
-(as chiltons says) reverse steps to install.
The only parts I couldn't find was the gaskets for the axles, but I made some out of felt......with some hunting and shipping ($80 from WA to MI through DHL for me) you can have a locked, loaded, and bullet proof eaton rear. for half the price of a rebuild on your 14b (just my 2/100 of a dollar)
Mine will have disc. brakes when the time to replace the drums come due!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 01-24-2008, 04:51 AM   #36
earl87gta
earl87gta's Avatar
Randy's sells every thing you need to rebuild it as far as seals and barings go. I thought I had a thread saved on this but I cant finf it. to do the 14blt hybrid axle you need the axles spider gears and a detriot for a 14blt ff axle use the spider gears and locker in the eaton carrier. then replace the eaton axles with the 14blt axles. for the disk breaks when I didn my 72 I used an adaptor for a 14blt with no mods needed so say you have to shave some off the spacer but i didnt have this trouble. I used a bent style disk break convertion and had no problems. I have never had to do the hybrid Ive broke a eaton axle and all of my eatons have the factory lockers. I try to keep one or 2 around just in case I need one but havent needed one yet.
Earl
Old 01-24-2008, 04:58 AM   #37
earl87gta
earl87gta's Avatar
one last thing with the disk swap if you are using an older eaton pre 69 you will have to drill the hubs out and go to a larger lug stud other wize the rotor will be loose on the studs. I tihnk 69 and up had the same size wheel studs as the 14blt axles and will match the rotors. try to use a rotor from the same year front end as your eaton. for the guys with the drum break fronts you will need to drill yours out and go to bigger studs.
I have herd of guys using the 14blt hubs but it taks some extra work to do.
Earl
Old 01-24-2008, 05:06 AM   #38
~Shep~
~Shep~'s Avatar
Just found this...
http://www.coloradok5.com/forums/sho...ybrid&t=144838
Anyone know this guy? He posted a pic...but will not come up.
JIMs70K25
New DD
1972 Cheyenne K20
Old 01-24-2008, 05:28 AM   #39
earl87gta
earl87gta's Avatar
dont no him but the eaton with the mog convertion is crazy.
Earl
Old 01-24-2008, 10:41 PM   #40
shelby987
shelby987's Avatar
earl87GTA, you are correct about the studs, but IIRC, 1970 was the last year of the small studs, I think (?????) the studs went from 1/2" to 9/16"
