#26 | |
Re: i broke a tap in my block!!!
http://www.engineeringhobbyist.com/p...val/index.html |
#27 |
#28 |
I have a great trick I learned from an old timer, and then I learned why it worked when I was in school. All you need is a oxy/acetylene torch. Cast iron (engine block material) cannot be cut with a torch, but the bolt or tap that you may have stuck in the block can be. All you have to do is heat the tap up to red with a torch, and then feather in the cutting oxygen, and it will blow out the tap or bolt and leave the threads in the block. Then all you need is to clean it up a little with a tap (carefully so you don't have to do it again), and your block will be as good as new. Hope this helps.
#29 | ||
FWIW.I never let it cool. For me the nut gets real hot, and welds well, but the broken part, being threaded into a giant heat sink can dissipate the heat pretty fast, may have oil on it, and often doesn't weld well, so the new nut just snaps off. Not to worry, just grab another nut, and weld it on there. a few tries, ant the bolt bottom is hot enough to get a good bond, and comes right out Most times I go for this method before trying any easy out, drill, or similar tool. A portable 110 MIG makes this a nice field repair that people are happy to pay for, but you can also do for a beer or two without loosing your shirt. I don't claim my way is the right way, just something a crazy old man showed me. Any fastener which is hot enough to glow a nice red will unthread easily, and it is now flexible enough to conform to the messed up threads around it.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#30 |
Gone to greener pastures
![]() Join Date: May 2007
I honestly dunno if this will work for a broken tap, or not. But if I had $1 for everybody I told it to for extracting a broken bolt; I'd be retired.
If you can get a good bite on the tap, i.e. it's not broken flush with, or below the block, try this. Get your vice grips set. Get out your propane torch & some wax. Bee's wax is most bestest, but candle wax will do just fine. Heat your tap (or bolt) with the torch. When you have it good and hot, hit it with the wax. The wax will be sucked into the threads. Grab it real quick like with the vice grips, & back it outta the hole. If it won't, or doesn't work with the tap, put this in the back of your head for your next busted bolt. I surely hope this is a help to you. Good luck. El Jay |
#31 |
yes, i do
ok so i want to heat the tap and not the block then?? i'm just trying to figure this out. unfortunately it is broke slightly below the deck and i do not have a mig welder at my disposal or i would have taken a bolt and weld it to the broken tap. so if i heat the tap/block could i grab the tap with a pair of pliers and attempt to unscrew the tap??
as a second thought, i may have a torch at my disposal and while reading the second link seems to me as a more viable option. i shall let you guys know how this turns out.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 Last edited by 60ratrod; 01-04-2008 at 12:14 AM. |
#32 |
yes, i do
ok so i decided to roll my truck into the weld booth at the auto hobby shop on base today(that's where she's been sitting). one of the guys who works at the auto hobby helped me with the welding a nut on the tap method, and low and behold 6 nuts later the tap is removed!! she's still apart and will go back together tomorrow. time for the happy dance!!
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#33 |
Way to go!
#34 |
Too Dumb To Know Better
Congrats!!
#35 |
GREAT!!!
I'm gonna remember that little trick, fo' sho'! |
#36 |
Sierra Grande Club
The Auto hobby shops are nice, I do some work at ours here at Kirtland AFB
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#37 |
thats good to here!
