01-17-2008, 12:25 PM | #26 |
Dave's not here, man
Re: Two piece driveline to one piece?
Sorry, they were on the page before that one. Here's a link to the page with prices. It's about 3/4's of the way down. You can also click on the "Springs & Rear End Components" link on the left side of the page at the top and it will take you to the area with the carrier bearings. It's in the subheading titled "Slip-Shaft Driveline".
http://www.classicperform.com/6092chevtrk.htm
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 01-17-2008 at 12:32 PM. |
01-17-2008, 04:05 PM | #27 |
WTB this ad
I had seen where when using the porterbuilt, guys were tunneling the back of the cab floor. If a 2 piece shaft was used do you think you could use a stock floor with a high hump?
01-17-2008, 04:32 PM | #28 |
you can lay frame with a two piece without cutting the cab floor, all with proper pinion angles.
01-17-2008, 05:11 PM | #29 |
WTB this ad
That's good to know.........Since I already gave away my 2 piece shaft. Oh well, I didn't think I would ever have a need for it. I gave it to a friend who has done a lot for me through the years. I guess if I end up having a new one built I still came out cheap, all things considered.
01-17-2008, 09:54 PM | #30 |
Here is the prices of the slip shaft driveline from CCP and a center bearing conversion that look realy hefty and bullit proof.
Slip Shaft Driveline CPSSD Slip Shaft Driveline (collapsed 33.75” - max expanded 36.5”), each $199.00 CPRCB Carrier Bearing - OEM rubber, each $29.00 CPPCB Carrier Bearing - billet & polyurethane, each $115.00 • Carrier Bearing Conversion Kit CSBC Bearing & Bracket, kit $129.00 CBC Bearing, kit $35.00 Buy CBB Bracket, kit $99.00
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
01-18-2008, 06:41 AM | #31 | |
its all about the +6 inches
I can't see any way that a chunk of billet aluminum being that cheap.... BEFORE they make it round. |
01-18-2008, 06:44 AM | #32 |
70+ ( Old Skool Club )
Ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
