#26 |
blood type; Retumbo
Re: oh no a knock!!!!
excactly panel, all 400s had a balanced , um, well balancer. it will possibly crack your crankshaft.
as for the 350 or 327 ones I first must ask what year is your 327. small journal or large journal? |
#27 |
Trucks N Tranzams
First the engine will vibrate, a lot. Power will suffer and then it will crack the crank.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#28 |
#29 |
Just a thought, but, do you NEED a new balancer? If it is not badly damaged, some cleaning up and a bit of peening may make it safe to just insert a new key, and tighten it down correctly using the right Loctite It would be easy enough to check frequently to be certain that it is holding - which it might do for 100k miles. If it begins to loosen, then get a new balancer and key.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
#30 | |
#31 |
So I finally got the 327 balancer and before installing it I decided to weigh it and compare the difference with the original balancer......the new balancer is 2lbs lighter then the balancer that came off. I rechecked to order I placed and it was correct for a 68' 327. I installed it and got it running again....looks great...no wobble....and pulls side ways like she always does.
