Old 02-02-2008, 06:41 PM   #26
oldspowered67C10
Re: help running exaust
I just posted this pic on the suspension forum for a similiar question. I ran mine out right behind the trans crossmember.
oldspowered67C10 is offline   Reply With Quote
Old 02-03-2008, 02:56 AM   #27
dznucks
dznucks's Avatar
travisH
thanks for the picture. that is exactly the way i want mine to look.
looks good.
do you have yours running? i was wandering if the x sounds different or runs different than the previous exhaust system you had
dznucks is offline   Reply With Quote
Old 02-03-2008, 07:20 AM   #28
TravisH
TravisH's Avatar
its not running yet, but my exhaust won't sound anything like it was before
TravisH is offline   Reply With Quote
Old 02-03-2008, 04:14 PM   #29
truckguy_69
truckguy_69's Avatar
travis im looking for closer shoots of where it exits under the frame and also how much clearence there is around the tail pipe.
truckguy_69 is offline   Reply With Quote
Old 02-03-2008, 09:35 PM   #30
see ten
WTB this ad
see ten's Avatar
I'm coming in to this thread a bit late and these pics are on the crappity side but here ya go.
I used the ECE extreme drop crossmember.
Also had a H pipe installed.
The drop we were working around is 6" out back.
Making the passenger side clear wasn't so tough.
The driver's side was a bit tight but it clears just fine.
Everything is tucked up above the height of the frame.
And a clean finish out the back.
see ten is offline   Reply With Quote
Old 02-04-2008, 08:26 AM   #31
TravisH
TravisH's Avatar
here ya go truckguy. I won't know how I want to end the exhaust until I get bedsides so for now I just let it run long
Old 02-04-2008, 09:15 AM   #32
ryan913
Has anyone used the new dual exhaust system from Thrush systems (734-348-7806) p/n 89027 with the holes cut into the crossmember? It looks to be a really nice set up with a x pipe. 2 1/2 aluminized mandrill bent pipe. It's for the 60-72 trucks.
ryan913 is offline   Reply With Quote
Old 02-04-2008, 09:15 AM   #33
truckguy_69
Thanks travis for the pics.
Old 05-12-2011, 03:34 PM   #34
weaintscared
weaintscared's Avatar
That some really nice pipe work
weaintscared is offline   Reply With Quote
