02-11-2008, 06:41 AM | #26 | |
Re: Closer
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-12-2008, 02:42 AM | #27 |
Re: Closer PROGRESS
I Guess Im Not Familiar With A Speed Bleeder What Is It??
And How Does It Work I Really Think I Have Some Air In The Lines Or Something Last edited by DANTES JIMMY; 02-12-2008 at 11:09 AM. |
02-16-2008, 12:05 AM | #28 |
Re: Closer
I had same problem--replaced MC, Prop Valve, brakes, calipers, wheel cyls---and bleeding till I bled! My local mech said to gravity bleed--just open the caliper valve a bit and let them run while keeping fluid in MC. Seemed to work---I also needed to just DRIVE it a bit. It finally hooked up.
03-05-2008, 05:05 PM | #29 |
ROCKWELL 5 TON CLUB !!
Re: Closer
hey man ,thats a really nice looking k5.i didnt know you were building that.
i really like the orange,i wish i could decide on a color for mine. no farther away from you than i am ,give me a shout if you need any help w/anything. later andy
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
05-03-2008, 06:14 AM | #30 |
Future TOTM Winner
Re: Closer
What did you decide to do about the floor? Did you find a Rubber mat?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
05-03-2008, 09:08 PM | #31 |
Re: Closer
i think i will go lmc it looks to be the better of all that i have found
have to wait on the budget to allow it |
05-04-2008, 12:21 AM | #32 |
Re: Closer
I put a 3/4-1 ton booster in mine as the 1/2ton boosters are single diaphram and the 3/4-1 tons are dual diaphrams, the peddle is effortless and locks them down if needed. I had the same deal all new and a rock hard peddle and when a panic stop came up, nothing, now I tap it and stop!! Looks sweet, I would avoid rubber if you can as my nice rust free (yeah) AZ Blazer had rust because the rubber mat (original) held water under it and the only place it rusted was in the floors under driver's feet, was still wet under there when i pulled it out. Maybe a spray in liner, then you can get it wet and not worry?? Sweet, BTW
05-04-2008, 12:24 AM | #33 |
Re: Closer
You did an excellent job on that restoration. I love the color combo including the painted bumpers and grille. That would look good even if you didn't chrome it. Welcome to the club you can see mine in the signature link below. Someday I will end up driving it back to Evansville.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
05-04-2008, 04:51 PM | #34 |
PROJECT 7DEUCE
Re: Closer
Wow very nice love the orange...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
